Fri, Feb 7, 2:46 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 06 4:35 pm)
Subject: Ntdll.dll file problem with Poser8
722 ( ) posted Thu, 21 January 2010 at 5:40 PM · edited Thu, 30 January 2025 at 9:10 PM
Windows vista 64    problem  with ntdll.dll file hangs poser8 at render  , all 4 cpus will be working at full , and then thired way throught the render it stops as if the render is completed and then crashes.
Has anyone else had this  problem ?
pjz99 ( ) posted Thu, 21 January 2010 at 7:21 PM
Haven't had that, and you should report it to SM for sure, but you might try to disable "Separate Process" in Edit menu -> General Preferences -> Render.
My Freebies
722 ( ) posted Thu, 21 January 2010 at 8:04 PM
yes i talked to SM about it and they told me that i could update my video card driver to see if that would work , and that it looked like the problem might be with the windows file and i would need to take the problem with Microsoft so i did  they had a lot on the problem with the ntdll.dll file but only for Win XP not vista 64, so got in contact with them and they said it was not there problem and i would need to contact the computers manufacture, can you see where this is going LOL
pjz99 ( ) posted Thu, 21 January 2010 at 8:07 PM
Disable "Separate Process" and see if it lets you work around it.
My Freebies
722 ( ) posted Thu, 21 January 2010 at 8:48 PM
Ill try that
markschum ( ) posted Thu, 21 January 2010 at 10:11 PM
try reading rhis
http://www.computerhope.com/issues/ch000961.htm
http://www.computerhope.com/issues/ch000960.htm
its mainly driver updates that might help.
