Wed, Dec 25, 12:43 PM CST
Subject: Visemes in 3rd Party Figures
redtiger7 ( ) posted Tue, 12 February 2008 at 7:41 PM · edited Wed, 25 December 2024 at 1:43 AM
I just started using Talk Designer (P7) and wanted to use it with Vitoria 4. But it asks for the viseme file and I can't find V4's. (Even though I have the phenomes. I tried using one of teh ones included with P7, but it didn't work too well. Anybody know if and where I can get Viseme files for 3rd party characters?
stallion ( ) posted Tue, 12 February 2008 at 8:26 PM
Attached Link: Talk Designer expansion Kit
you want the talk designer expansion kit over at content paradise
support for over 200 characters
You might as well PAY attention, because you can't afford FREE speech
redtiger7 ( ) posted Tue, 12 February 2008 at 8:34 PM
cool. thanks
Ricky_Java ( ) posted Fri, 25 September 2009 at 11:00 AM
Hi,
It appears that Content Paradise has dropped the Talk Designer Expansion product from its catalog, as the above link now defaults to their home page, and a search of the site comes up empty. My Google search of the Web also came up empty. Does anyone know if the product is still available, or if not, why it was discontinued?
I see that bluegene has kindly offered a solution for V4 here in FreeStuff, but no such luck for poor V3. I may have to create my own. If I do and can get it working, I'll share it here too.
Thanks,
Ricky
Anakele ( ) posted Thu, 21 January 2010 at 10:31 PM
Attached Link: http://www.contentparadise.com/ProductDetails.aspx?id=12805
you can also try Talk Designer Assistant for Poser 8: http://www.contentparadise.com/ProductDetails.aspx?id=12805
RichardCoffey ( ) posted Fri, 22 January 2010 at 8:39 AM
Hi,
Thanks, Anakele. Apparently the Expansion has been replaced by the Assistant.
Richard
LostinSpaceman ( ) posted Fri, 22 January 2010 at 11:19 AM · edited Fri, 22 January 2010 at 11:21 AM
Or you could make your DAZ Figures Dork compatible by spawning the same expression morphs the P4 Dork or P5 Don use. How you ask? Here are the steps:
Place Don/Dork and your 3rd party figure in Poser side by side. Dial Don or Dorks expression morphs to 1.0 one at a time. Use your 3rd party figures existing morph dials to pose their face to match each and every expression morph of Don/Dork and then go to Poser's Object menu and click "Spawn Morph Target" and spawn a morph with the exact same name as the one used by Don/Dork for that expression. Once you've gone through and copied each expression morph to your 3rd party figure in that manner you end up with a figure that can use any animated talking pose that Dork or Don can use. This also works with Posette or Judy for the females.
This works with both Talk Designer AND Mimic!
Anakele ( ) posted Fri, 22 January 2010 at 11:31 AM
LostinSpaceman,
    You are almost right about Talk Designer.  You are ignoring the problematic of the teeth and tongue.  They are are dependant on some of the expression morphs but they're displacement will not be added to any new spawned morphs.  If I am wrong please post a video to that affect.
Anakele
sixus1 ( ) posted Fri, 22 January 2010 at 2:43 PM
Attached Link: http://www.sixus1.com/forums/viewtopic.php?f=34&t=201
This is how I make my own Viseme files
LostinSpaceman ( ) posted Fri, 22 January 2010 at 5:24 PM
You're quite right. I am ignoring the teeth and Tongue of the M4 V4 figures. My methods worked fine up to the Millenium 3 figures though. I haven't bothered to update them for the Mil4 figures because I haven't personally had the need to do so.
Quote - LostinSpaceman,
Anakele
