Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 8:41 am)
A blue /green diffuse -blender node using the displacement map as a mask?
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
It would have helped if you had the displacement expanded so that we could see it.
I'll guess that the veins are light grey on a darker grey background. You need a black background. Try running the displacement map to a math function node (subtract) and subtract 0.5 or whatever it takes to just reach a black background. Run this output to another math node to take the square root to restore some dynamic range. Run that output to the root shader node's displacement input.
OSes: Win7Prox64, Win7Ultx64
It wasn't my image, it was from the person who suggested it.
"You need a black background. Try running the displacement map to a math function node (subtract) and subtract 0.5 or whatever it takes to just reach a black background. Run this output to another math node to take the square root to restore some dynamic range. Run that output to the root shader node's displacement input."
I think that's what the M4 displacement maps do, so I will try copying their nodes.
Quote - It would have helped if you had the displacement expanded so that we could see it.
That's right, I posted that Screen Capture, and my displacement is black Background with veins in white and shades of gray, that's how the displacement map must be to work this way, and the veins map must be plugged to the displacement channel not the bump
Ok, here is a node function which will get you the de-oxegenated looking veins with displacement, using TrekkieGrrrl's map.
Image map 4 is TrekkieGrrrl's vein bump/dsplc map. Its output -the purple "cable"- plugs into the upper socket of the math node in the bottom right corner.
The math nodes process it and hand it off from right to left, ending with an image that has grey veins on a black background. The last math node (bottom left) then plugs into the displacement socket and also controls the amount of blending.
seachnasigh,
I confer the title of Node Elf upon you.
I asked this in a thread about displacement maps for H3.
So we can use displacement maps to make veins on skin, but how can they be colored to look like the greenish blue veins beneath human skin?
