Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 16 10:02 pm)
Attached Link: http://www.drgeep.com/p5/introp5/introp5.htm
The above was done for Poser 5 but might help.
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Sorry, I was just able to duplicate your problem. No Dots visible on 1280x720 screen.*
Note - at screen resolution of 1280 x 768, the Dots are just visible in the lower left corner
Do you have this option? Can you use?
cheers,
dr geep ... :o]
edited 10/5/2019
Dr. Geep. Think I solved it. I used maximum resolution and then opened up
poser.The memory dots were visible in the lower left. I took it and piled everything
else in the center of the screen and saved them as preferences. I then reset
the resolution back down to 1280 X 720 and then opened poser. It was barely
there in the lower left . I rearranged all the items back to their correct positions
and saved them in preferences. I tried and opening poser again and everything was
there. Thanks for all your help.
Hello, I got a new computer and installed poser 6 on it. at
a screen resolution of 1280 X 720 , the memory dots dont
show. at screen resolution of 1920 X 1080, the memory dots
appear but everything is tiny. my bad eyesight prevents me from
using this resolution . does anyone know a procedure to relocate
the memory dots into the visible area of the screen at
1280X720? i have tried to restall poser but it didn't fix it.
thanks for any ideas.
