Forum Moderators: Staff
The correct way to load the figures is to first load the null, then with "BODY" on the null selected add the actual figure. Then... select the null [BODY] you loaded first and add the second figure. If there is a third figure, select the null [BODY] again and add it next. There is no need to add a second/third/etc null, you only use one. -Rob rbtwhiz.com
when i add a null to my scene, then replace it with a figure, THEN add a second null and replace that with a second figure, (using vicki) it still ends up missing tons of body parts; anyone know a better way to get 2 vicki's into one scene?
