Sun, Feb 9, 12:48 AM CST
Subject: you modelers! how can I make a change in V4 that ...
softcris ( ) posted Fri, 05 February 2010 at 12:39 PM · edited Thu, 06 February 2025 at 3:49 AM
Yeah! I'm thinking in a possibility to make a change (PoserPro or Poser8) in V4. Like some kind of 'egg' like in both legs and arms to start.
These'eggs' should not loose the 'legs movements' but maitain these as well.
Anyone can tell -me how to?
thanks
"'you shut up!  or I'll bring democracy to your country! "
Cris Galvão aka Softcris  - www.crisgalvao.com
(or softcris, SoftCris)
Rendering since 1997 and
at Renderosity since 1999.
OS Win 8.1     64 bit
markschum ( ) posted Fri, 05 February 2010 at 3:07 PM
I dont understand exactly what you are after. You can parent a prop to the leg, upper or lower and it will follow any animation of the leg.
softcris ( ) posted Fri, 05 February 2010 at 10:04 PM
Ok, I'm trying to make an 'egg' in the knees region. Like a small egg attached to the joints. The V4 should move/pose normally with the 'joint egged'. Easier to undestand?
OS Win 8.1     64 bit
WandW ( ) posted Sat, 06 February 2010 at 8:27 AM · edited Sat, 06 February 2010 at 8:29 AM
Do you mean like those of a Pak Protector:
www.absoluteastronomy.com/topics/Pak_Protector
Or those of Popeye the Sailor:
www.popeyefreshfoods.com/index.php
BTW, I like your sig.  I should try that line the next time I see my Congressman!  :biggrin:
SamTherapy ( ) posted Sat, 06 February 2010 at 8:41 AM
Quote - Do you mean like those of a Pak Protector:
I'd love to see a Poser version of a Pak Protector.  Loved those books immensely, even if Niven did run out of ideas a few years ago.
softcris ( ) posted Sat, 06 February 2010 at 1:57 PM
Ok, like Pak Protector. any clues how to make that?
OS Win 8.1     64 bit
3Dave ( ) posted Sat, 06 February 2010 at 3:12 PM · edited Sat, 06 February 2010 at 3:13 PM
Looks like this could be do-able with a magnet at the top of the shin, use a fairly small mag zone positioned over the joint, in the magnet properties tab, click "Add element to deform" and then select the thigh. expand the magnet's x and z scale and perhaps move the magnet forward a little to avoid too much bulge at the back. None of this should affect the joint's functionality.
softcris ( ) posted Sun, 07 February 2010 at 9:51 AM
kind of complicated for me..but I'm trying anyway...so far a disaster! Thanks for the tip! I'll exercice it until I make it. :)
OS Win 8.1     64 bit
3Dave ( ) posted Mon, 08 February 2010 at 4:56 PM
Hi softcris, thought I'd double check what I posted, especially as I just had a problem with a magnet crossing a joint on a clothing item. The way M4 is set up though means its not an issue here (shin and thigh are divided above the knee) no need to add "elements to deform" Hopefully this is something like what you are aiming for. My display units are set to "Feet"
MagBase
scale 14%
x, y & z 0 degrees rotation
x tran -0.287
y tran 1.659
z tran -0.013
Magnet
scale 112%
x scale 155%
y scale 115%
z scale 136%
y rot 0
x rot -1
z rot 0
x tran 0.0
y tran -0.697
z tran 0.163
MagZone
scale 4%
x scale 198%
y scale 118%
z scale 100%
y rot 0
x rot -51
z rot 0
x tran -0.287
y tran 1.652
z tran 0.193
softcris ( ) posted Tue, 09 February 2010 at 2:36 AM
OH! You're my god!
I was needig something like that...I have being sweating to make a 'magnet' small and in the right place! Now you gave me the recipe!
Thanks a thousands times! I'll be back with my final work.
thanks, thanks
Cris
OS Win 8.1     64 bit
