Fri, Nov 8, 7:46 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 05 6:14 pm)
Subject: help render problem
ladiesmen ( ) posted Sat, 13 February 2010 at 1:50 AM · edited Fri, 08 November 2024 at 7:42 PM
Hello all
Ok first some info. I have desktop with quad core 2.4G and 8 gig of memory. 1Tb HDD so that should be ok.
The problem:
I have scene that takes long render time above 6 hours so I want to do at night. The problem is I start render around let say 9 pm and can see it goes ok until I sleep. This night I even checked around 3 am when was short awake. This morning however DS 3adv program was closed. I had same yesterday so me lost why.
I turned the sleep mode of my system OFF just to make sure,
I looked at the log file also but cant find reason or even statement at give dates that DS closed.
Hope you have tips
thks
You can also reach me on skype.com to talk name ladiesmen22
People dont care what you know, until they know you care
Use Quad core with 8G memory & ATI 5770
Poser Pro 7 & Poser 8 Sr3
Daz 3.2 adv 64 bit
RHaseltine ( ) posted Sat, 13 February 2010 at 8:28 AM
What did the end of the log file say? Are you sure it wasn't something like an update causing a system reset?
ladiesmen ( ) posted Mon, 15 February 2010 at 2:19 PM
thks for help offer. Maybe indeed system update or something. The log file just shows close of DS like normal. I did the render again during day and worked normal
thks
Daz 3.2 adv 64 bit
Skip1871 ( ) posted Thu, 18 February 2010 at 10:09 AM
 Hi, I used to have similar issues on my old system - it turned out to be Windows going into power save mode two hours after I'd left it alone.
What I ended up doing was going into my control panel and turning off all the functions like 'sleep', 'power save mode' and then in the system management tab, turning up automatic updates as this can prompt the machine to restart.
I then manually switched the screen off, put the keyboard upright so the cats couldn't land on it and went to bed :) all worked fine.
The next day I just re-enabled the power save modes and automatic updates. It only took a couple of minutes, once I'd figured it out.
Best of luck! I know how frustrating it can be to see a blank screen or half a file where you're hoping for a beautiful render.
Madbat ( ) posted Fri, 19 February 2010 at 8:20 PM
I do almost all of that on my system as well...except I stuff my keyboard tray under the desk cause my cats always seem to stand on the power button...then there's the touchscreen controls for my monitor....
Come to think of it, most of my prep work for a midnight render involves cat proofing!
ladiesmen ( ) posted Sat, 20 February 2010 at 2:19 AM
ahahaha thks all. Yes cats are a 3D hazard for sure. LOL
Daz 3.2 adv 64 bit
Madbat ( ) posted Sat, 20 February 2010 at 3:59 AM
Actually, I should have mentioned that any time I have that problem it's usually because of something updating, or my system went into sleep-mode or some such. Once those details were looked after I've been able to do 87 hour renders. (don't ask)
