Tue, Jan 7, 12:56 AM CST
Subject: Please can someone help me im to old to pull all my hair out
avalonbears ( ) posted Mon, 15 February 2010 at 2:19 PM · edited Tue, 07 January 2025 at 12:52 AM
Ohh lordie can someone help me please is on knees bit of a lie but not far off :D
I just upgraded from vue 6 to vue 7 why why the hell did I do that?
be still taggart
Ok here is my prob, I bring things from poser over to vue, course alpha plane for the ease and cut down on size...... alpha plane sobs why ohhh why won't my alpha plane work?
I click box to add alpha plane, inside said box as in vue 6 I stuff a fairy, except I don't get a fairy, I get leafs lots of leafs, if I don't get leaves cough I get brick wall, no fairy, nada none, shes there if I double click my alpha plane box, but she aint there if render or anything else just leaves walls walls and leaves, and I feel a bit mad now you know that neither here nor there feeling
In vue 6 (which i am about to put back on) - I click alpha plane, I go to my pick, it auto puts the bmp in there is the fairy floating in mid air in a see through box.
Vue 7 I load the same do the same, there it is a wall floating solid in mid air :(
please can someone tell me what is wrong with my vue 7 or should I just give up after two days and put 6 back on, and or jump up and down on the vue 7 disk which is a wasted bday pressy :(
Thank you for your time and patience listening to my dyslexic ramblings of a mad woman
avalonbears
FrankT ( ) posted Mon, 15 February 2010 at 2:26 PM · edited Mon, 15 February 2010 at 2:26 PM
some pictures of what is going wrong might help to diagnose it.
[edit]
you are rendering an image out of Poser and loading it onto the alpha plane in Vue ?
My Freebies
Buy stuff on RedBubble
melikia ( ) posted Mon, 15 February 2010 at 2:27 PM · edited Mon, 15 February 2010 at 2:28 PM
I feel your pain, avalonbears.
I don't have a solution, but i also don't think this is typical behavior.  Am hoping someone here is better able to assist you.
don't jump up and down on the disc quite yet =D
hang in there...
~meli
ps... i love Vue 7, and once you get this figured out and can play around, I think you will, too - it took me a few weeks when i went from 6 to 7 to fully appreciate the upgrade.... =D
Editted to add:  Have you made sure you've applied the latest updates???
Rarer than a hairy egg and madder than a box of frogs....
< o > < o >    You've been VUED!    < o > < o >
         O                                                    O
avalonbears ( ) posted Mon, 15 February 2010 at 2:41 PM
Hello :)
Nono not rendering from poser to vue, rendered in poser then alpha'd into vue as you would do, done hundreds of these in vue 6 :) vue 7 hates me though, pfft I am starting to feel mutual hate.
I thaught ahhh ahhh yesterday I had done a vue 6, so I braught in the alpha plane
for an orchid I did yesterday, sigh this is what it did, a squirrels ear hole and a faded out
nice effect though but still faded out orchid, but as you see in the alpha there is
the squirrel.
disclaimer no animals were hurt during this process
Hope you can help, usually it shows a solid alpha box with just a brick wall in,
even the preset fishes come out purple brick texture with a fish outline, the box is never a
non solid, something is just not happening not sure what though.
avalonbears ( ) posted Mon, 15 February 2010 at 2:45 PM · edited Mon, 15 February 2010 at 2:51 PM
Ok tried again, reloaded the scene, braught up the alpha box and chose a fish, one big fish, this is what I always get whatever I choose the one above is new problem.
Last pic to be done in Vue 6
FrankT ( ) posted Mon, 15 February 2010 at 2:55 PM
first thing is to make sure you are running the latest update to Vue7.  You can get it from the e-on site.  That might help (I just tried it in Vue7 infinite and it works as expected provided there's an alpha for whatever it is I'm using)
from the image you've posted, I'd expect to see an image of a squirrel looking cute but not an orchid.  Where are the images you are trying to load coming from ?
Step by step if you'd be so kind.  There might be something in the process that's going wrong
My Freebies
avalonbears ( ) posted Mon, 15 February 2010 at 3:01 PM
I shall go and see e-on site first for updates :) better check this, using just a normal png really.
Could be a flower anything no background n all that, but i'll go check for updates and let you all know, this is hugely appreciated.
avalonbears ( ) posted Mon, 15 February 2010 at 3:16 PM
Ok now I am highly ashamed :D and the moral of the story is UPDATE omg two solid days going mad thank you so very much it really is hugely appreciated, and here is cookie ok not a good render but hey :D amazing what an update can do blushes madly
Thank you so very much
FrankT ( ) posted Mon, 15 February 2010 at 3:23 PM
glad you got it working in the end - it's always good to check for updates if Vue is doing something weird.  :biggrin:
My Freebies
Mazak ( ) posted Mon, 15 February 2010 at 4:37 PM
I am glad you solved your problem. But keep in mind if you use many transparent objects (Alpha planes) keep an eye on the Max Trace level in Sub ray Options! Default is 5 but if you have problems with transparency use a higher value!
Mazak
Google+ Bodo Nittel
