Thu, Nov 14, 7:13 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: Quicktime pro on XP
santolina-sailor ( ) posted Thu, 18 February 2010 at 2:38 PM · edited Thu, 14 November 2024 at 7:13 AM
Will Quick time pro run on XP PC or is it only a Mac app?
BAR-CODE ( ) posted Thu, 18 February 2010 at 2:42 PM
did you actualy checked the site ?
IF YOU WANT TO CONTACT BAR-CODE SENT A  PM to 26FAHRENHEIT  "same person"
Chris
My Free Stuff
Khai-J-Bach ( ) posted Thu, 18 February 2010 at 2:47 PM
erm yes if it's the windows version.......
santolina-sailor ( ) posted Thu, 18 February 2010 at 3:01 PM
Quote - erm yes if it's the windows version.......
Erm-- Yes and coulnt find anything,dont worry Im haveing a bad hair day,and thanks for the info,-)
hborre ( ) posted Thu, 18 February 2010 at 3:20 PM
Quicktime has been a standard on PC's for quite some time.
LaurieA ( ) posted Thu, 18 February 2010 at 4:07 PM
Quote - Quicktime has been a standard on PC's for quite some time.
Since, um, Windows 95 ;o).
Khai-J-Bach ( ) posted Thu, 18 February 2010 at 4:08 PM
windows 3.1 ;)
santolina-sailor ( ) posted Thu, 18 February 2010 at 5:02 PM
Quote - > Quote - Quicktime has been a standard on PC's for quite some time.
Face now colour of beetroot--Pass me the gun theres one bullet left
hborre ( ) posted Thu, 18 February 2010 at 5:23 PM
LOL!!!
lmckenzie ( ) posted Fri, 19 February 2010 at 6:19 AM
I assume you're thinking of using it for encoding. For playback, you can use VLC player or get the utility "QuickTime Alternative".
Google uninstall quicktime and you'll see that getting it in may be easy but once it's slimy tentacles are embedded good luck :-)
santolina-sailor ( ) posted Fri, 19 February 2010 at 7:02 AM
Quote - I assume you're thinking of using it for encoding. For playback, you can use VLC player or get the utility "QuickTime Alternative".
What Im wanting to do is convert my images files BMP from a movie and convert them to QT with Q T pro,from there I can make good conversion to flash FLV for the web
 No I wont touch the Google alterative thanks--hate tentacles anyway.I downloaded QT vers 7 and when Apple sort their act out Ill get the key--right now they want an ITunes Id from me(which I dont have)when i tell them I dont have one they say OK Itoons Password which I dont have either,so going slowly crazy.
JenX ( ) posted Sat, 20 February 2010 at 11:03 AM
 ...what he means is type "Uninstall Quicktime" into the search engine.  Quicktime is infinitely harder to get rid of than it is to install...
Khai-J-Bach ( ) posted Sat, 20 February 2010 at 11:07 AM
ain't that the truth.... Quicktime Alternative (nothing to do with Google - that was actually meant as 'use google to find' - it gets shortened to google this) is a lot easier to deal with...
santolina-sailor ( ) posted Sat, 20 February 2010 at 11:48 AM
Quote -  ...what he means is type "Uninstall Quicktime" into the search engine.  Quicktime is infinitely harder to get rid of than it is to install...
I wasnt aware of this as I uninstalled the old version before installing Q T 7 for the pro version Key and as far as I can tell .no adverse effects.
santolina-sailor ( ) posted Sat, 20 February 2010 at 12:08 PM
Quote - > Quote -  ...what he means is type "Uninstall Quicktime" into the search engine.  Quicktime is infinitely harder to get rid of than it is to install...
I just eventually found a page that found my old password for Itunes and it went ok from there,thanks for the heads up though,and Ive bookmarked one of the sites with a fixin next time,
I took Itunes out 8 months ago,loads of problems,although I still get regular up date popups from them.
lmckenzie ( ) posted Sun, 21 February 2010 at 6:42 AM
You know when a cottage industry has evolved around getting rid of/avoiding an application that something ain't right. 'Real Alternative' is a similar utility to eliminate the need to install the equally tenacious RealPlayer.
santolina-sailor ( ) posted Sun, 21 February 2010 at 9:14 AM
Quote - You know when a cottage industry has evolved around getting rid of/avoiding an application that something ain't right. 'Real Alternative' is a similar utility to eliminate the need to install the equally tenacious RealPlayer.
RealTime and I are no longer communicating.A total screw up!
