Mon, Feb 3, 2:46 PM CST
Subject: Just got Poser 8 and I have a question
CMKook-24601 ( ) posted Fri, 26 February 2010 at 1:17 PM · edited Thu, 01 August 2024 at 7:15 PM
 can I just copy the content from my poser 7 runtime folder in to poser 8 or do I have to re-install all my content?
markschum ( ) posted Fri, 26 February 2010 at 1:24 PM
You might be best to ADD the Poser 7 runtime as an external runtime than to merge it.
If you merge it copy the contents of runtime/geometries  runtime/textures and runtime/libraries over.
Belladzines ( ) posted Fri, 26 February 2010 at 1:25 PM
You can add Poser 7 to your Poser 8 library .... i dont remember how its done but its how i did it .... i think its add library or something - so you dont have to move or copy all your stuff from P7 to P8 and take up extra space.
CMKook-24601 ( ) posted Fri, 26 February 2010 at 1:39 PM
 can I do that and deinstall poser 7?
geep ( ) posted Fri, 26 February 2010 at 1:53 PM · edited Fri, 26 February 2010 at 1:59 PM
In the Library Palette ...
  On the upper right hand side ... Look for the File Folder with the Plus (+) sign and click it.
Now ... browse to your Poser 7 folder and click on it to add it to Poser 8.
And, ... that's all there is to it. 😄
cheers,
dr geep
P.S. If you deinstall Poser 7, you might lose the Poser 7 "Runtime"
If you do this ... you will lose it.
Here's what to do ...
Make a new Folder in your root directory (NOT in the Poser 7 folder)  named "P7Runtime" (or what ever you want).
Copy (or Move) the "Runtime" folder from your Poser7 directory to the new folder.
Now, you can deinstall Poser 7.
Now, "Add" (in Poser 8) the new folder you just created as a new Runtime in Poser 8.
cheers,
dr geep ... :o]
edited 10/5/2019
Belladzines ( ) posted Fri, 26 February 2010 at 1:55 PM
well no this is assuming you want to keep poser 7 on your system ...
i use both because poser 8 library system annoys me - i use its render engine for high res renders only ....
if you want to uninstall poser 7 then yes you will need to move your content over to Poser 8.
CMKook-24601 ( ) posted Fri, 26 February 2010 at 1:58 PM
Quote - well no this is assuming you want to keep poser 7 on your system ...
Okay so then that leads me back to the first question can I just move the content from one runtime folder to the other or do I have to re install it all?
geep ( ) posted Fri, 26 February 2010 at 2:01 PM · edited Fri, 26 February 2010 at 2:02 PM
No, if you have the P7 "Runtime" folder (complete) ... saved outside of the Poser 7 folder ...
Just open Poser 8 and  link it ("Add") it while you are in the Poser 8 Library.
("Add" = the Folder icon with the Plus (+) sign)
cheers,
dr geep ... :o]
edited 10/5/2019
CMKook-24601 ( ) posted Fri, 26 February 2010 at 2:01 PM
Quote - No, if you have the P7 "Runtime" folder (complete) ...
Just link it ("Add") it while you are in the Poser 8 Library.
(the Folder icon with the Plus (+) sign)
But I don't want poser 7 on my computer any more
geep ( ) posted Fri, 26 February 2010 at 2:05 PM · edited Fri, 26 February 2010 at 2:06 PM
Just save the Poser 7 "Runtime" folder somewhere (NOT in the Poser 7 folder)
Now deinstall Poser 7 ... Poser 7 ALL GONE ... (but the P7 content is saved)
Now go into Poser 8 Library and click the "Add" folder (Runtime that you saved from Poser 7)
Now you can access all your Poser 7 content inside the Poser 8 Library.
cheers,
dr geep ... :o]
edited 10/5/2019
CMKook-24601 ( ) posted Fri, 26 February 2010 at 2:05 PM
 Ah great Idea ^_^ thanks
IsaoShi ( ) posted Fri, 26 February 2010 at 2:50 PM
In case you have never added an external library before...
When you add a new library, you choose the parent folder of the Runtime folder. The name of this parent folder will become the Poser display name for the new Library.
So it would be a good idea, in your case, to copy the Poser 7 Runtime into a new folder called, say, "Poser 7 Content".
Sorry if you already got past that point....
