Mon, Feb 10, 1:00 PM CST
Subject: Howto Copy Animation and Not Figure
kkrawal ( ) posted Tue, 02 March 2010 at 11:43 PM · edited Mon, 10 February 2025 at 12:41 PM
I got Poser5 and Poser7.
I have created one Walk cycle for 25 Frame from Frame 1 to Frame 25.
I want to create loop.  The complete Animation will be for 150 Frame, How to loop this animation. The loop should run 6 times and after a new animation will start from Frame 151 to Frame 251.
2nd Problem I have one more character and I want to use the same loop for this character.
On 2nd character the same loop will start from Frame 10 to Farme 60. ( 2 times )
Can any one please guide how to do this.
MistyLaraCarrara ( ) posted Wed, 03 March 2010 at 8:52 AM
you can save an animated pose.  It'll ask you how many frames you want to save.
At frame 26, you would apply the animated pose, etc.
markschum ( ) posted Wed, 03 March 2010 at 10:23 AM
the animated pose is easiest . You can copy and paste keyframes in the keyframe editor.
Ockham had a script called Repeater . at www.ockhamsbungalow.com/python
kkrawal ( ) posted Wed, 03 March 2010 at 8:21 PM
Thanks for reply. I have gone thru the tutorials and found that saving pose is the eastiest thing in Poser. You create some animation and Select Pose, Click on + and you will be prompted to save. It saves immediately and you can goto any Frame No and can call that pose.
Thanks for support.
