Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 12 9:36 pm)
You're not by any chance related to alfa-16 over at the IMDB boards are you?
dph
This sounds like something that BagginsBill might know about.
dph
FAULT Detected!
[FaultEvent fault=[RPC Fault faultString="HTTP request error" faultCode="Server.Error.Request" faultDetail="Error: [IOErrorEvent type="ioError" bubbles=false cancelable=false eventPhase=2 text="Error #2032"]. URL: http://127.0.0.1:11530/apps/lms/api.py"] messageId="AEBF808F-DE25-5823-D18B-3A69A4228091" type="fault" bubbles=false cancelable=true eventPhase=2] --- Fault Request Info:
op=appConfig
I run LSMGUI.html and all is OK
You re-installed P8. Did you update to SR2.1? Just making sure - no point in debugging an earlier release.
Now - the fault you get indicates that the very first message (appConfig) between the GUI and Poser is failing.
Likely causes have to do with firewalls.
Less likely causes have to do with wrong Flash version installed.
Honestly, I've given up knowing all the reasons this happens. After you make sure all software is up to date, if you still need help, get it from SM.
They have a catalog of all the things people do/have wrong on their systems. I don't.
In particular, ratscloset knows everything!!!
Hi All,
Had to re install P8 onto my new vista laptop. I followed BB's fix for no lib in view. Now i get this were the lib should be in GUI.
Any help
Regards
I attached a file...honest!!! where is it
