Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 20 7:20 am)
Move the item from the library onto the figure onto wich you want it to conform.
Keep the mouse button pressed until you see "Add and Conform" - this might take a few seconds if the library is still filling (after you start PoserPro). Then release the mouse button. After the library has filled it goes a lot quicker
If the item is autoconforming, you don't need to check any boxes. If is not you might need to check the Include morphs checkbox.
Be sure you drag the item onto a body part which is not covered by a clothing item since it then may conform to that item instead of the figure
This is how it works for me
Does the mouse pointer change at all while you're dragging?
That's interesting. Glad you found a way to make it work. I was not aware that Vista UAC includes the ability to prevent you from dragging content between windows. Amazing. I'll file that little tidbit away for the next person.
Hi.
can somebody tell me if there is something I need to do to enable the drag
and drop function in PoserPro2010?....I havebeen trying to drag conforming
clothes on to models with no luck. It's one of the main reasons I upgraded :(
thinking it would save me a lot of time. Has anybody else had probs?
Thanks
Using VistaUlt.
