Sat, Oct 5, 9:22 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 05 8:08 am)
Subject: P7 -External Runtimes -contents went POOF! (help?)
Rosemaryr ( ) posted Sat, 13 March 2010 at 6:57 AM · edited Sat, 05 October 2024 at 7:19 AM
So I keep my stuff organized in external runtimes, organized by the major categories that i use (ie., Michael, Victoria, Animals, Hair, etc.)
I go to open P7, and work on a cloth room WIP I had set up but not finished.  Wanted to add a movement pose to Mike to get some extra draping going.
I click to load my Michael runtime to the library list, it shows up on the library list, but then, there's nothing showing inside:  No figures, no poses, no nothing.
Same thing with my Victoria runtime.
The Hair runtime loads fine, as does Animals...everything where it should be.
Why would Poser see one runtime and it's contents, but not another, which is set up exactly the same????  Granted the Michael and Victoria runtimes  are huge* compared to the others, but I've had no such trouble before.
Suggestions?  I'm about to remove P7, and re-install if that what it takes....but would like to avoid the hassle, if possible.
RosemaryR
"This...this is magnificent!"
"Oh, yeah. Ooooo. Aaaaah. That's how it starts.
Then, later, there's ...running. And....screaming."
WandW ( ) posted Sat, 13 March 2010 at 7:01 AM
Did you try removing the offending runtimes from the Library, then re-adding them?
Rosemaryr ( ) posted Sat, 13 March 2010 at 7:18 AM
Yup.  No good.
Even (showing how desperate I was...) went into my computer's folders to double check that the contents hadn't been somehow deleted!
RosemaryR
WandW ( ) posted Sat, 13 March 2010 at 8:35 AM
Just a thought; are you on a Mac or Windows?
I have had issues with the case of sundirectory names when running Poser under Linux, such as finding a 'libraries' folder and a 'Libraries' folder in a Runtime after installing content.  The result is that you don't see the contents of the folder you expect to.  This isn't an issue on Windows, but could be on a Mac, since underneath that pretty GUI,  it is good old UNIX...
WandW ( ) posted Sat, 13 March 2010 at 8:53 AM
My editing time expired..
If you are on WindowsXP, with Poser closed, go to this folder (I'm not quite sure where it exists on VISTA):
C:Documents and Settings{Your User Name} Application DataPoser 7 (you will need to turn on View Hidden Directories to browse to it) and rename or delete the file  'LibraryPrefs.xml'  Poser will create a new one when it restarts.  You can the try adding the misbehaving runtime to the library
If this doesn't work, try renaming the whole folder and Poser will create a new one.
Rosemaryr ( ) posted Sat, 13 March 2010 at 8:58 AM
PC, WindowsXP.
Setup is (example):
C:PoserStuff:Mike:Runtime:(subfolders as determined by installation process; ie. Geometries, Libraries, etc.)
Same structure for every runtime.
Poser is 'seeing' the "Mike" and "Vicky" supra-folder names and adding them to the library list, but not showing anything inside of it.
Have my runtimes gotten too large to load?? (Eeech, what a thought!)
RosemaryR
WandW ( ) posted Sat, 13 March 2010 at 9:09 AM
My v4 runtime is 9.4GB with almost 40,000 files and it loads OK.  I suppose there must be a limit, but I don't know what it is.
Try nuking the preference file as noted above...
Rosemaryr ( ) posted Sat, 13 March 2010 at 10:11 AM · edited Sat, 13 March 2010 at 10:24 AM
Radiation-resistant!  Nuking ineffective.
(sigh)
Trying to re-name the "Mike" folder and see if that makes a difference.
(later)
Nope, that doesn't do it either.  ALL of the other runtimes load (and unload) properly.  But Michael and Victoria just won't show up at all!  (Getting frustrated and ready to punch the computer!!)
RosemaryR
Rosemaryr ( ) posted Sat, 13 March 2010 at 10:56 AM
Gave up, did a full re-install of P7.  That seems to have finally put things to rights.  sigh
Now maybe I can stop wasting time fixing things, and get back to working the stuff!!!
Thanks for your time on this, WandW!!  I do appreciate your holding my hand through this!
(Hugz)
RosemaryR
flibbits ( ) posted Sat, 13 March 2010 at 11:25 AM
It happened to me but the entire directory (on the disk) was gone.  When I restored it from a backup the textures were still gone so anything that had textures was toast.
WandW ( ) posted Sat, 13 March 2010 at 11:46 AM
Glad it's fixed.Make sure you reinstall the service releases and content update if you haven't already.
