Tue, Dec 31, 11:58 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 31 9:20 pm)
Subject: Why would magnets not work?
Prometheus273 ( ) posted Tue, 16 March 2010 at 3:24 PM · edited Tue, 31 December 2024 at 11:35 PM
A friend is trying to morph a set of jewelry.  The Jewelry is a separate figure that conforms to another figure.  She's trying to use a magnet to reshape the large bracelets.  Each bracelet is a "forearm" of the jewelry figure.  No matter what she does, the magnet has no influence on the jewelry forearm whether the figure is conformed or not.
She had the jewelry's forearm selected when she made the magnet.
The jewelry forearm is not  locked.
The jewelry figure itself is not locked.
There are multiple material zones in the jewelry forearm, but the magnet has no influence on any of them.
Even if she adds all the other elements of the figure to the magnet, nothing happens.
She even exported the forearm out as an .OBJ and then imported it as a prop.  A magnet still had no influence on it, even as a prop.
I ran out of ideas.
PhilC ( ) posted Tue, 16 March 2010 at 3:39 PM
Is bending turned off?
Is the magnet zone positioned to enclose the object?
Prometheus273 ( ) posted Tue, 16 March 2010 at 4:07 PM · edited Tue, 16 March 2010 at 4:09 PM
Hi Phil,
I know the magnet zone was positioned to enclose the object.  In fact, I know the falloff zone was increased just to see if that would have any effect.  But I'll ask about bending and report back.
Update:  "Bend body parts" is enabled.
PhilC ( ) posted Tue, 16 March 2010 at 4:17 PM
I'd be happy to take a look at the files if that will help.
Prometheus273 ( ) posted Tue, 16 March 2010 at 5:46 PM
Thanks Phil,
Send to:
pcooke@philc.net
Miss Nancy ( ) posted Tue, 16 March 2010 at 5:48 PM
"replace body part with prop" usu. prevents bending, for reason mentioned above.
the other reason is insufficient polygonal density in angle of bend, which would be
unlikely, unless cylinder primitive used.
Prometheus273 ( ) posted Tue, 16 March 2010 at 5:58 PM
I'm waiting to get the files from her.  I asked her about the polygon count and she says it's quite detailed.
PhilC ( ) posted Tue, 16 March 2010 at 6:13 PM
Yes or use the form on my upload page.
http://www.philc.net/upload.php
PhilC ( ) posted Wed, 17 March 2010 at 5:38 AM · edited Wed, 17 March 2010 at 5:41 AM
What you sent me had bends turned off. When I turned bends back on the magnets worked.
Incidentally did you try to upload from a Mac or PC?
Prometheus273 ( ) posted Wed, 17 March 2010 at 12:45 PM
Ohhhh.  When you said bend, I thought you were referring to "Bend body parts" from the menu on top.  I checked "Bend" from the properties tab as shown and it worked.  Thank you very much!  By the way, I tried to upload from a PC.
