Mon, Feb 3, 5:57 AM CST
Subject: General Preferences Tab for Rending for Poser 7
ladyperiwinkle ( ) posted Thu, 25 March 2010 at 10:57 AM · edited Mon, 03 February 2025 at 5:52 AM
I keep getting kicked out of Poser when rending it says I need to to change my adapation threshold and change bucket size -- I went to  this tab to change things and now nothing renders -- I can only render using Poser 4 -- what are the default rendings for this tab setting in Poser 7 -- what settings in this tab can I change to have this render better for larger pictures of lots of objects and characters
hborre ( ) posted Thu, 25 March 2010 at 11:06 AM
Have you tried checking on the 'Separate Process' in the Render Process?  That may solve your problem.
Medzinatar ( ) posted Thu, 25 March 2010 at 12:03 PM
adaption default is 0.375 and memory limit is 32 (you can get all defaults by picking launch to factory state on first page of general prefs).
the "number of threads" would be the number of cores/threads you have on CPU.
hborre ( ) posted Thu, 25 March 2010 at 12:13 PM
IIRC, P7's bucket size default is 64.  I could be wrong, and if I am, I apologize for my error.  I am currently not at my home computer to verify.
Medzinatar ( ) posted Thu, 25 March 2010 at 1:26 PM
I'm not sure, the default bucket may be determined by users system memory.
In any case, if you check adaptive bucket size, it will size down when hits threshhold, although you don't see any change in number.
ladyperiwinkle ( ) posted Fri, 26 March 2010 at 11:29 AM
Thank you all so much!!!
