Fri, Dec 27, 8:02 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 26 8:04 pm)
Subject: Poser 8 issue - not rendering everything.
andromedakun ( ) posted Fri, 26 March 2010 at 3:50 AM · edited Fri, 27 December 2024 at 7:52 AM
Hello all,
I'm having some weird issues with Poser 8 since a bit of time now. When I render and change the post filter size to a value of 3 or more, the render will start then block for a while, leave a whole part black and continue some point further in the render.
Anyone noticed the same issue?
Andro
Dave-So ( ) posted Sat, 27 March 2010 at 8:59 AM
not that, but I posted an issue similar couple of weeks ago and no one responded. It rendered nearly 2/3, then partial render part around the mouth etc, then finished later . The areas not rendered were pixillated..i was using IDL.
Humankind has not woven the web of life. We are but one thread within it.
Whatever we do to the web, we do to ourselves. All things are bound together.
All things connect......Chief Seattle, 1854
vilters ( ) posted Sat, 27 March 2010 at 9:12 AM
and what are your PC specs and render settings?
andromedakun ( ) posted Mon, 29 March 2010 at 7:54 AM
Ok, here goes the specs:
Intel I7 940 (2,88 Ghz quad core)
6 GB of tripple channel DDR3 RAM
Nvidia Geforce 285 GTX Graphics card
1TB Sata2 HD
Windows Vista 64.
settings used:
Render resolution: 1500 x 2000
Raytracing: 5 or 6
Indirect lightning: Off
Smooth Polygons
Shadows on
Some other stuff I don't know by heart :p
I hope this replies ;)
Many thanks for your answers ;)
Plutom ( ) posted Mon, 29 March 2010 at 8:48 AM
It is supposed to do that because Poser is using multiple threads.  It will work on the black parts and continue to render the easier parts at the same time.  Mine will continue to render until 99 percent complete and appears stalled with those black patches.  However Poser is still computing those areas and will finish up in a few minutes.  Jan
andromedakun ( ) posted Mon, 29 March 2010 at 12:19 PM
Hi Plutom,
I can understand this happens, but when Poser tells me the render is finished and the CPU goes to 0% usage, I assume he finished. I even let the computer render a whole night for a simple scene with V4, some cloth behind her and 3 lights with some fairly good settings and still nothing came out of it...
*settings to follow
Andro.
Plutom ( ) posted Mon, 29 March 2010 at 1:27 PM
Try this, (it could be one of your third party add ons, eg hair, a dress, etc). Eliminate or make invisible everything except the nude figures.  Then begin adding stuff until it fails and isolate what part of that third party stuff is doing it.   Jan
andromedakun ( ) posted Mon, 29 March 2010 at 1:58 PM
Aye Pluton, but I tried a few different things, the only thing I know causes the issue about for sure is when I put the postfilter thing to Sync and 3... I'll post the results tomorow morning after a brief render tonight :p
Andro
