Sat, Jan 11, 2:25 AM CST
Subject: Daz Cyclorama and Poser pro 2010
Pol ( ) posted Mon, 29 March 2010 at 5:08 PM · edited Mon, 23 December 2024 at 11:04 AM
Hi,
I've been trying to install it, but no success. I's an .exe package.
Cheers
WandW ( ) posted Mon, 29 March 2010 at 6:39 PM
If there is an option to install it for DAZ Studio, try that option...
hborre ( ) posted Mon, 29 March 2010 at 6:40 PM
Or create a dummy Poser.exe and place it in the folder of your choice.
seachnasaigh ( ) posted Tue, 30 March 2010 at 12:09 AM
I use hborre's method;  here's an explanation.
DAZ's installers look for Poser.exe to locate where to install;  Pro versions have a PoserPro.exe instead, so the Daz installer gets lost in the woods.
So, make a simple Notepad text ("This is a Poser executable dummy file because DAZ installers are not too smart.") and save it, changing the file type suffix to .exe and place in the Poser Pro 2010 top folder where the PoserPro.exe is located.
Pol ( ) posted Tue, 30 March 2010 at 3:00 AM
Many thanks guys, I'll try it tonight.
Lucifer_The_Dark ( ) posted Tue, 30 March 2010 at 3:57 AM
I just answered the same thing in the other thread, didn't notice this one till too late. :D
Windows 7 64Bit
Poser Pro 2010 SR1
Medzinatar ( ) posted Tue, 30 March 2010 at 7:21 AM
on the older installers, like cyclorama, when dialog comes up saying "searching for installed components", hit cancel and it take you later to menu to select directory for install.
If you having multiple runtimes this may be better than putting dummy file in each folder.
WandW ( ) posted Tue, 30 March 2010 at 7:31 AM
Quote - I use hborre's method;  here's an explanation...
I do too, but I don't have PP, so I didn't know what the PP executable's name was.  It would be a shame to add a text file called 'poser.exe' if there already was a real poser.exe...  😉
Lucifer_The_Dark ( ) posted Tue, 30 March 2010 at 8:59 AM
Poser Pro & Poser Pro 2010 both have an executable called PoserPro.exe, I don't generally install anything to the main Poser runtime & have a folder set up elsewhere specifically for installing Daz stuff to where I put the Poser.exe txt file.
Windows 7 64Bit
Poser Pro 2010 SR1
hborre ( ) posted Tue, 30 March 2010 at 9:21 AM
Medzinatar is correct.  Many older installers do search for the Poser.exe automatically and will flag if not found.  Cancelling the search will work 100%.  However, newbies and individuals upgrading to the Pro series will encounter the unusual error and will subsequently panic unnecessarily.
nruddock ( ) posted Tue, 30 March 2010 at 2:42 PM
Quote - Cancelling the search will work 100%.
And IIRC, some of the really old installers, you must cancel the search to avoid a crash (due to incompatabilities with newer Windows versions).
Also given how much larger disks are, you'd spend a huge amount of time waiting for the search to finish for each installer.
Pol ( ) posted Tue, 30 March 2010 at 5:29 PM
Thank you so much.
