Fri, Jan 10, 11:27 PM CST
Renderosity Forums / Carrara
Welcome to the Carrara Forum
Carrara F.A.Q (Last Updated: 2025 Jan 10 10:15 am)
Carrara Free Stuff here.
Subject: Toon Shader in 6.2
TonyL ( ) posted Fri, 02 April 2010 at 12:58 PM · edited Fri, 10 January 2025 at 11:12 PM
Hi!
Could somebody direct me to a tutorial on using the Toon Shader in Carrara 6.2?
Thanx!
holyforest ( ) posted Fri, 02 April 2010 at 1:38 PM
 Just a little suggestion for Toon! Pro:
http://www.digitalcarversguild.com/plugin.php?ProductId=15
Holyforest,
Hundreds of shaders for Carrara
TonyL ( ) posted Fri, 02 April 2010 at 1:48 PM
It looks very nice but I don't need something that involved and since I am on Social Security I have to be careful what I spend money on.
pauljs75 ( ) posted Sat, 03 April 2010 at 7:06 PM
Attached Link: http://blog.zgock-lab.net/poser/yatoon/en/
You might be interested in the Yet Another Toon shader.
It's a nice freebie that gives a cell-style (toon) shading effect at the shader rather than render or scene effects level. (You can mix cartoonish with realistic that way.) It drops in under the lighting model at the master shader level once installed, and has 9 adjustments for fine tuning. Looking at the ReadMe file before using it is a good idea, since it uses some of the normal shader channels in different ways.
Alternately if you want to try the "Toon!" thing that seems to come with Carrara 6 Pro, it's enabled by applying a filter to the scene instance. It works on the whole scene rather than specific objects when enabled, but you can apply an overide under object effects to dial down or exclude things from it. There should be some info in the Carrara help .pdf file on it. I haven't seen any tutorials spefic to this myself (at least as far as I care to search), but maybe we'll get lucky and somebody will pop up with an answer.
Barbequed Pixels?
bwtr ( ) posted Sat, 03 April 2010 at 11:48 PM
You should find all the answers in the Help
Look in the "Building a scene"---"Cartoon Rendering".
Brian
bwtr
TonyL ( ) posted Sun, 04 April 2010 at 8:00 AM
Thanks for all the help, folks! I'm slowly getting the hang of it.
Tony
