Fri, Jan 24, 6:24 PM CST
Photoshop F.A.Q (Last Updated: 2025 Jan 14 1:57 am)
Are you up to the challenge??
Subject: How to reduce thumbnail to 15k or below
drgnmztr ( ) posted Sun, 04 April 2010 at 5:33 PM · edited Fri, 24 January 2025 at 6:20 PM
Ok, I've uploaded thumbs for my pics before but for some reason I can't get the thumb below 21.7k so I  can't upload. I need to upload a thumb for violence type pic.
I'm using Adobe Photoshop CS2. I'm just not figuring it out. I make a thumb 100x100 and reduce EVERYTHING to its lowest possible and then save and it won't go below 21.7k. I'm getting frustrated. any help would be appreciated. Also, in the prog when saving, it says its like 6.xx in size but its not.
LukeA ( ) posted Sun, 04 April 2010 at 5:37 PM
Do you have the Save for Web option?
LukeA
My latest novel
drgnmztr ( ) posted Sun, 04 April 2010 at 5:38 PM
Yes.. should I try that? does it give me other options?
Ravyns ( ) posted Sun, 04 April 2010 at 5:58 PM
If it's the same as PS 7 you should get a screen that has a little box you can check for optimizing & under that should be a slider bar that you can use to adjust your thumbnail down to 15 k..
Life may not be the party we hoped for but while we're here we should dance.
LaurieA ( ) posted Sun, 04 April 2010 at 5:59 PM
Use Save for Web. You can reduce the resolution accordingly. There's a slider in there that allows you to keep reducing the resolution as needed. You can probably use a 200x200 pixel thumb as well if you use that option.
drgnmztr ( ) posted Sun, 04 April 2010 at 6:13 PM
Guess it worked since I uploaded the pic and thumb. thank you. happy easter
dreamer101 ( ) posted Sun, 04 April 2010 at 10:31 PM
I don't bother with the sliders. I click the Optimize menu pulldown in the Save for Web window and select "Optimize to File Size..." and plug in 21.7 (or whatever size) in the "Desired File Size" box.
Jeff_Kraschinski ( ) posted Wed, 21 April 2010 at 7:54 PM
If you have an option NOT to save metadata in the file, that helps as well...
Getting rid of ANYTHING extraneous will help save the most space possible for image data.
