Sun, Feb 9, 7:48 AM CST
Subject: Car paint - a challenge
  • 1
  • 2
pjanak ( ) posted Wed, 07 April 2010 at 9:51 PM · edited Wed, 07 April 2010 at 9:56 PM
Attached Link: http://i41.tinypic.com/wk0n4z.png
So here is another render. Turns out the errors seen on the Nova were caused by the smooth polygons setting. So I turned it off. Despite the errors in the previous render I still like it better than this one. Pete
bagginsbill ( ) posted Wed, 07 April 2010 at 10:15 PM
Looks great. I noticed the left front tire is passing through the fender a tiny bit.
pjanak ( ) posted Wed, 07 April 2010 at 10:27 PM
Yep. I've got the tread bump set to "1" displacement. I'm going to see what it looks like with no displacement. I also did a crappy job with the nearby trees. I think I should have just used trees from one of the environment backdrops
bagginsbill ( ) posted Wed, 07 April 2010 at 10:52 PM · edited Wed, 07 April 2010 at 10:53 PM
A tread bump like that we usually want to offset so it makes grooves, cutting into the tire. Instead of expanding the treads, you want to shrink everything that is not-tread.
Hook the displacement map up to a Color_math node. Set Value_1 = white and connect to the map. Click on Value_2's color and sample the brightest spot on the tread map. Hook the Color_Math node to the displacement channel.
This will cause the bright spot to be neutral - no change - and everything darker will be a depression. Thus - the radius of the tire will not be altered.
  • 1
  • 2
