Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 7:14 pm)
Hit Send to Recycle bin. Run poser. If it works, you're done. If it crashes, you undelete the folder.
I have a 64-bit system. When I installed, there was a little check box on one of the installation screens with a check mark in for 32-bit files. I unchecked that box and did not install the 32-bit material. I was lucky to see this little box, and I wonder if a more prominent notice should be placed in the installer.(maybe an uninstall and reinstall is the easiest or safest way to approach this.)
So far I have not noticed any effect from not having the 32-bit material. In fact, Pro 2010 is the best poser version that I have used, and that goes back to version 3.
I only run the 64 bit version. Can I delete the files in program files x86 (32-bit version)? It's over a gig (a giggity gig).
