Sat, Feb 8, 9:19 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 08 9:05 am)
Subject: Delete 32-Bit Poser Pro 2010
flibbits ( ) posted Thu, 08 April 2010 at 3:05 PM · edited Sat, 08 February 2025 at 9:07 AM
I only run the 64 bit version.  Can I delete the files in program files x86 (32-bit version)?  It's over a gig (a giggity gig).
bagginsbill ( ) posted Thu, 08 April 2010 at 3:15 PM
Hit Send to Recycle bin. Run poser. If it works, you're done. If it crashes, you undelete the folder.
flibbits ( ) posted Thu, 08 April 2010 at 3:18 PM
I didn't think of that.  Thanks.
spod ( ) posted Thu, 08 April 2010 at 3:26 PM
I have a 64-bit system.  When I installed, there was a little check box on one of the installation screens with a check mark in for 32-bit files. I unchecked that box and did not install the 32-bit material.  I was lucky to see this little box, and I wonder if a more prominent notice should be placed in the installer.(maybe an uninstall and reinstall is the easiest or safest way to approach this.)
So far I have not noticed any effect from not having the 32-bit material.  In fact, Pro 2010 is the best poser version that I have used, and that goes back to version 3.
NoelCan ( ) posted Thu, 08 April 2010 at 10:56 PM
     "      In fact, Pro 2010 is the best poser version that I have used, and that goes back to version 3.   "
Ditto From Me..  I go back to version 2..
One issue is that like P8,  there is the occasional CPU grab that slows everything
D
.O
W
N
