Mon, Jan 20, 9:04 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 20 7:34 am)
Subject: AO on a skin shader? Ugh!
Winterclaw ( ) posted Mon, 12 April 2010 at 3:12 PM · edited Mon, 20 January 2025 at 8:57 AM
I was just playing around with a character I had bought awhile ago and it had an AO node on the skin shader which produced this result.  Looks pretty ugly, doesn't it?
I tried turning on my diffuse light which had AO turned on, and that helped a little, but it was far from perfect.  So short of yelling at the vendor or manually fixing every node on every save (and there are a ton of them because this vendor gives a lot of pose files with different options) do I have any more practical and quick options for getting rid of the unwanted AO nodes?
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
hborre ( ) posted Mon, 12 April 2010 at 3:25 PM
No other practical way other than using BagginsBill's VSSPR3 prop.
bagginsbill ( ) posted Mon, 12 April 2010 at 3:35 PM
Yeah, use VSS and not only will you be able to get rid of AO in one click, but you'll actually have a skin shader that works right.
Winterclaw ( ) posted Mon, 12 April 2010 at 8:43 PM
VSS it is then.  Thanks guys.
Normally I'd prefer not having to change what a vendor makes but in terms of shader set up...  good or bad it is their vision, however I just don't want to work with that kind of problem.
WARK!
Winterclaw ( ) posted Tue, 13 April 2010 at 10:04 PM
Okay, here is the same character with VSS.  It seems to have darkened the skin a little, but it's gotten rid of the big problem.
PS.  I did send the vendor a PM, I'm still waiting to see if they send any reply.
WARK!
hborre ( ) posted Tue, 13 April 2010 at 11:26 PM
Darkening due to gamma correction.  Your original post had way too much specular lighting.
Winterclaw ( ) posted Wed, 14 April 2010 at 12:27 AM
True... but at this point I'm kinda used to too much specular lighting.
WARK!
bagginsbill ( ) posted Wed, 14 April 2010 at 7:50 AM
That looks good, IMO. To compare to see what the specular effect is doing, set PM:Shine to 0.
If you want more specular, in the VSS Template_Skin, increase the PM:Shine Level parameter. In the absence of a specular map, VSS uses the color map to control the specular level. Since different maps have different overall luminosity, this means that there is no single universal value that does what you want with all texture sets. But the adjustment is trivial.
If you want more of a shiny/hydrated look, increase PM:Shine. This simultaneously modifies level and spread. Level is the brightness of the specular reflection. Spread is how broad the specular reflection is. I provide all three controls - level and spread as separate parameters to fine tune the balance, and shine as the overall control that modifies both.
To lighten the skin diffuse reflection alone, increase PM:Diffuse Reflectivity to .8 or .85.
To brighten the entire shader, go to the bottom and increase PM:Boost above 1.
To make the skin color map lighter, scroll to the right side of Template Skin and find the Color Map. Decrease the Texture_Strength. Be warned, though, that this can lighten eyebrows unacceptably if you do it too much.
To be able to seriously lighten a skin texture, even to the point of making it white, while preserving lip, makup, and eyebrow colors, get my Albino shader here:
http://sites.google.com/site/bagginsbill/free-stuff/random-shaders/VSSAlbinoSkin.mt5?attredirects=0&d=1
To see what that can do, search this forum for posts by me using the word albino.
Winterclaw ( ) posted Thu, 15 April 2010 at 3:53 PM
I've played with it a little bit and skin reflectivity .seems to be the best way to go for the moment.  I saw what you meant about shine giving a shiny/hydrated (oily?) look.  Then for some reason I played with the color tint to see if I could get a good twiliek look going.
WARK!
