Wed, Feb 26, 5:34 PM CST
Forum Moderators: RedPhantom
Subject: spider-man for M4
ice-boy ( ) posted Thu, 15 April 2010 at 1:28 PM · edited Wed, 26 February 2025 at 5:34 PM
i am doing spiderman for M4. its not perfect and the webbing on the suit is not good. but after 2 weeks of texturing i am giving up. i also modeled simple ''boots'' and a very low poly mask .
the best way to practice modeling and texturing is to have a project to work on.
hborre ( ) posted Thu, 15 April 2010 at 2:46 PM
It does look pretty good.  Do you think you'll be doing a scene render with him?
ice-boy ( ) posted Thu, 15 April 2010 at 2:50 PM
can i realese this in the free section?
markschum ( ) posted Thu, 15 April 2010 at 2:51 PM
looks good .
hborre ( ) posted Thu, 15 April 2010 at 2:52 PM
I don't see why not.
ice-boy ( ) posted Thu, 15 April 2010 at 2:55 PM
then i will need some help.
i used Xurge3D Cr2 for the boots and for the mask. i tryed to writte it myself but it didnt work. i think i can not realese this free with xurge3D's CR2  right?
ice-boy ( ) posted Thu, 15 April 2010 at 2:57 PM
i think i will also realese all the photoshop files with all the layers for the web,symbols and masks. that way everyone can tweak the textures .
hborre ( ) posted Thu, 15 April 2010 at 3:00 PM
That sounds about right to me.  You can get as far as offering the textures and stating that the user must own such and such item to complete the costume.
ice-boy ( ) posted Thu, 15 April 2010 at 3:16 PM
i can not find a blank M4 CR2 file where i would only insert teh path for my mask and boots. its needs to eb conforming.
ice-boy ( ) posted Fri, 16 April 2010 at 7:27 AM
Trask ( ) posted Fri, 16 April 2010 at 8:00 AM
Looks good.
hmm, bet there could be a creative use with the "loop making script" by Cage to do some webbing effects.  I haven't looked closely enough to be sure though.
hborre ( ) posted Fri, 16 April 2010 at 8:47 AM
That looks excellent!
Anthanasius ( ) posted Sun, 18 April 2010 at 7:35 PM · edited Sun, 18 April 2010 at 7:38 PM
Hi !
Tried this material ( really good !!! ), is there some special morphs for m4 or the clothes ?
Cause something is a little strange :o
Génération mobiles Le Forum / Le Site
ice-boy ( ) posted Mon, 19 April 2010 at 4:11 AM
to fix the boots select the boots and ''zero  figure''
ice-boy ( ) posted Mon, 19 April 2010 at 4:13 AM
its in the CR2. the CR2 had some numbers messed up. i forgot to change it. if you go to ''zero figure'' for the boots it should fix it.
kamion ( ) posted Mon, 19 April 2010 at 4:40 AM
in which version op Poser is this done?
because in Poser 7 and Poser 8 there is no option: zero figure
ice-boy ( ) posted Mon, 19 April 2010 at 5:08 AM
i did this in poser pro 2010.
i asked on the forum if someone can help me with the CR2 file. if you know how to fix the CR2 file to use for the conforming clothes i will change it.
ice-boy ( ) posted Mon, 19 April 2010 at 5:09 AM
if someone will make a better texture for the webbing it would be nice if you would post it in this thread.
ice-boy ( ) posted Mon, 19 April 2010 at 5:11 AM
Quote - in which version op Poser is this done?
try  changing all the numbers on the body parts to zero.
-bend
-twist
-side
hborre ( ) posted Mon, 19 April 2010 at 6:01 AM
Zero figure is found in the Joint editor.
kamion ( ) posted Mon, 19 April 2010 at 7:04 AM
the zero-ing works fine,
actually I never used Joint-Editors as I hardly understand it's function.
two remarks:
the texture on the fingernails is either blue or white, while it's red in the cartoon, easy to fix in photoshop giving the texturemap red at the location  of the fingernails.
in the mask there are a few obstructive polygons that show up only when some posefiles are applied to M4
kamion ( ) posted Mon, 19 April 2010 at 7:32 AM
I noticed that the disturbance in the Mask is caused when the neck of M4 is twisted or sided
other movement of M4 does not cause it.
Anthanasius ( ) posted Mon, 19 April 2010 at 7:34 AM
It work nice, many thx ice-boy :-)
hborre ( ) posted Mon, 19 April 2010 at 1:03 PM
Nice render!
ice-boy ( ) posted Tue, 20 April 2010 at 2:06 AM
Quote - I noticed that the disturbance in the Mask is caused when the neck of M4 is twisted or sided
this is a big problem that i didnt notice.
will fix this.
ice-boy ( ) posted Tue, 20 April 2010 at 2:08 AM
i just loaded the material on M4 and the fingernails on the hand are red.
ice-boy ( ) posted Tue, 20 April 2010 at 2:28 AM
i think i fixed now the neck on the mask.
sorry for the problems.
you have to understand i didnt do this for the free section. i did this for me and to practice modeling and texturing. i just realesed this for free because not enough free stuff is realesed for M4. i think M4 is a good figure for superhero renders. so perfect for spiderman.
kamion ( ) posted Tue, 20 April 2010 at 2:58 AM
it's not critisism to your product, I like the product and am thankfull for it.
the important thing you have fun in designing this kind of stuff and probably want to have it working perfect too. just a notice of a minor glitch.
often freebee supporters take more care about their product then some vendors, who just ignore it when a glitch is brought to attention.
ice-boy ( ) posted Tue, 20 April 2010 at 3:05 AM
does the neck work now?
kamion ( ) posted Tue, 20 April 2010 at 3:10 AM
sorry, I haven't had time to reïnstall it yet, will do it sometime today.
ice-boy ( ) posted Wed, 21 April 2010 at 5:17 AM
Quote - the zero-ing works fine,
two remarks:
where did you get that pose of him on the wall?
are there any free spiderman poses ?
kamion ( ) posted Wed, 21 April 2010 at 6:09 AM
the zip where these poses are from is called
RMP_HeroActM4_73451
and I purchased it february 2009
but I have no clue at which site I found it
here's another one
the web is from Animotions
ice-boy ( ) posted Wed, 21 April 2010 at 6:31 AM
i see the boots work now.
the render look good.
violet ( ) posted Tue, 27 April 2010 at 8:14 AM
kamion ( ) posted Tue, 27 April 2010 at 9:23 AM
yip, violet, that's the set I used.
wonder why I could not retrace it.
violet ( ) posted Tue, 27 April 2010 at 9:51 AM
Looks like a great set....!
I found some action  poses for V4 also very useful for Spidey...
BionicRooster ( ) posted Fri, 14 May 2010 at 10:59 PM
Forum Moderator
when I noticed the neck problem, I just made a transparency map for that part of the body and it worked out fine for me. Seemed an easy enough fix.
Poser 10
Octane Render
Wings 3D
Tucan-Tiki ( ) posted Sun, 16 May 2010 at 5:43 AM
I seen about 4 or 5 attempts at spiderman I think yours is so far the best, I bet black suit spiderman will be awesome with your figure as well.
ice-boy ( ) posted Sun, 16 May 2010 at 6:59 AM
the conforming clothes,boots,masks and textures can be shared through e-mail and through private message on this forum.
ThunderStone ( ) posted Sun, 16 May 2010 at 8:06 AM
I did the black spiderman but for some reason I don't like the mask... it's has an opening at the base of the neck that isn't closed in to the neck, you can see it when you view it from the side. Otherwise it's a nice get up tho.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
Tucan-Tiki ( ) posted Tue, 22 June 2010 at 11:33 PM
link in free stuff not working today but when I downloaded it a day or two agoe the file was corrupted and would not extract from winrar, any chance of a new upload?
Tucan-Tiki ( ) posted Tue, 22 June 2010 at 11:58 PM
ok i went and downloaded it again, this time it did download but still the header in the win rar file is reading as broken the eror says unknown method broken header.
Tucan-Tiki ( ) posted Wed, 23 June 2010 at 12:02 AM
ok figured it out not currupted internet exploerer 8 was blocking it.
files ok its fine.
thank you
ice-boy ( ) posted Wed, 23 June 2010 at 1:14 AM
in 2 or 3 weeks i will fix the mask and add some body morphs to the boots and mask.
bodybuilder and bulk.
