Tue, Nov 26, 4:16 AM CST
Subject: Program to edit obj?
nerd ( ) posted Wed, 13 October 1999 at 8:52 PM · edited Tue, 26 November 2024 at 4:04 AM
Forum Moderator
Is there a cheap program out there that can edit the OBJ format. I'm tired of going throught half a dozen file formats to work on figures.
JeffH ( ) posted Wed, 13 October 1999 at 10:11 PM
RDS 5.02 is the cheapest one that I know of if you can still find it. -JH.
nerd ( ) posted Wed, 13 October 1999 at 10:47 PM
Forum Moderator
Is that Day Dream Studio. If so I have 5 and it doesn't do OBJ firmat. Is 5.02 a patch that will allow OBJ?
JeffH ( ) posted Thu, 14 October 1999 at 9:25 AM
The 5.02 update and the Plugin addition from Poser3. Update to 5.02 then... Do a custom install from the Poser3 CD and check in only the RDS plugins. This will update the modeler to handle obj format. -JH.
Kevin ( ) posted Thu, 14 October 1999 at 12:43 PM
You should also download the poser extension patches from meta's site. I think the obj plugin upgrades are useful also.
nerd ( ) posted Fri, 15 October 1999 at 12:32 AM
Forum Moderator
Using P4 so the plugin doesn't exist. I found the obj plugin for RDS finally. It does import, but good grief the figure, heck an entire scene in a little dot. I can't even zoom in enough to work on it. Man I think I'm gunna go back to using sPatch. I woudda saved a ton of dough. What is a poser unit? A nanometer? You'd think MC would rig their applications to speak the same language. Sigh... I guess if this was easy it wouldn't be fun right?
JeffH ( ) posted Fri, 15 October 1999 at 8:52 AM
The RDS OBJ plugin won't do, you need the update to the Mesh Form modeler. I'll see if I can find the stand-alone update on the MC FTP site. -JH.
JeffH ( ) posted Fri, 15 October 1999 at 9:01 AM
Here it is, I hope you're on windows. The Mac version must be in another directory there. ftp://ftp.metacreations.com/pub/Applications/rds/update/win/Win_obj.zip Be sure you don't end up with two copies of the OBJ plugin in the directory, that will no doubt cause errors. -JH.
Kevin ( ) posted Fri, 15 October 1999 at 9:13 AM
I think it is http://www5.metacreations.com/downloads/rds_plugins.html. The meshform modeler update seems to be claimed to be hidden in the obj module. They used to make it clearer which was which....
JeffH ( ) posted Fri, 15 October 1999 at 9:27 AM
Nope, the MFM update isn't linked there at all anymore. I had to find it in the directory listing. -JH.
bloodsong ( ) posted Fri, 15 October 1999 at 10:56 AM
uh... so whats the difference between the obj update and the mfm update?? i have the 5.0.2 update and the poser patch, i dont need to worry, right?
Kevin ( ) posted Fri, 15 October 1999 at 10:59 AM
The mfm update jeff found is the same one that came with poser, IIRC. It is an improvement from the one with 5.02.
Maz ( ) posted Fri, 15 October 1999 at 2:34 PM
nerd, you can get round the microscopic size problem by using my Objaction Scaler utility (PC only I'm afraid) to enlarge the obj file by 1000 or more before importing it. You can then scale it down again when you go the other way. It's on my site at http://www.sandylodge.demon.co.uk
