Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 08 10:28 pm)
BagginsBill is actually on holidays (vacation) atm... but I'm sure when he comes back he'll be able to sort this for you. You might do a search on RDNA for this problem... I dimly remember ('dimly' is a much stronger term than 'remember' in this case) that this issue has cropped up before.
Glad you got it sorted - sounds like something I would do. :blink:
Have a look on this forum for sample code... Acadia has a sticky at the top of the forum for threads relating to Matmatic. You will find yourself converting shaders from node-sets to scripts, eventually: well, you will if you're OCD like me. In trying to do that with BB's stocking shader (for which he's only ever submitted a node set).
It's all very enlightening! You're on an exciting journey: get a copy of NotePad++ -- it has syntax colouring, and is free -- and have a good time! Ask on here if you run into dramas. If I'm on but don't know the answer, I'll be sure to make something up... :tongue2:
LOL. I was just catching up to older posts. While on vacation, I was reading the forum occasionally via my phone. My phone browser does not support the the Javascript editor used by this forum to make posts, so I was unable to reply. Anyway, during vacation, I read this thread and I was going to tell you it was obvious to me that you were running compiler, not compile, but I could not.
Glad you figured it out.
(VSS is working great, BTW. Thanks for the help with that.)
Now I'm having trouble with Matmatic. I'm running Poser 6 (SR3, if it matters), and I installed the P5 or 6 beta (I double-checked). It's in my main runtime folder, at I:PoserRuntimePythonmatmatic . I run the compiler, and it throws this error:
Traceback (most recent call last):
File "C:Program FilesCurious LabsPoser 5RuntimePythonmatmaticcompiler.py", line 8, in ?
ImportError: No module named scriptContext
Same message with verbose set to 2. Even though it's a different error, I tried the alternate compile.py on Bagginsbill's site, and that didn't work so I went back to the original. I can see scriptContext.pyc sitting there in the matmatic folder. I tried making a fake Poser directory on my C drive and copying the Matmatic files there to see if it was looking for a hardcoded path, but that didn't change anything.
Any idea what's broken and how to fix it?
