Sun, Nov 17, 5:26 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 12 7:03 am)
Subject: exporting booleans
tomasball ( ) posted Sat, 24 April 2010 at 6:14 PM · edited Fri, 08 November 2024 at 10:19 AM
Maybe I have a fundamental misunderstanding here, but...
I'm using Bryce 6.3, and I understood that it would allow you to convert booleans into meshes and export them.  I'm unable to do that.
Here's what I did:  I created a cube, and made its attributes positive...made a negative sphere, grouped them together.  It renders like a cube with a spherical bit out of it.  Then I click on "convert Boolean to mesh" and it transforms just like it should.  Then I go to Menu: file: Export Object, and nothing happens.  "Export Object" is illuminated, and I'm able to click on it, but nothing happens.
If I make a boolean group with two terrains, or with a terrain and a cube, the same thing happens...or I should say doesn't happen.
If I import an object, like a cylindar made in another program, make it positive and group it with a negative cube, everything looks good, and it even exports.  but when  Ire- import the same object, it is the original cylindar, with no boolean subtraction.
peedy ( ) posted Sun, 25 April 2010 at 12:23 AM
Dou you group the cube and sphere?
You have to, in order to have the pos/neg work.
Then you can easily export, as far as I know.
And it should re-open as the grouped export.
Does that make sense?
Corrie
tomasball ( ) posted Sun, 25 April 2010 at 12:33 AM
If you will re-read my post, you will see that I grouped the cube and sphere, and rendered the result as a positive-negative boolean.
To follow up, I just installed Bryce 7, and had none of the problems I had in Bryce 6.3.  I am still interested to know why 6.3 didn't  work.
peedy ( ) posted Sun, 25 April 2010 at 12:41 AM
Oops, sorry.
I still use 6.1, so I can't help you on 6.3
TheBryster ( ) posted Sun, 25 April 2010 at 7:53 AM
Forum Moderator
That's very strange. It appears that you are doing things correctly. Sorry, stratchy-head thing I'm afraid.
skiwillgee ( ) posted Sun, 25 April 2010 at 2:24 PM
My B6.3 duplicates the same problem as described.  I had never exported created boolean objects before so I didn't realize a problem.
I too can import objects then export that same object but not so if the coverted group was created in the scene.  Puzzling.
Is there anyone with B6.3 that can export the stuff?
TheBryster ( ) posted Sun, 25 April 2010 at 3:41 PM
Forum Moderator
I'm sure I exported stuff in this way with no problem, but it was a long while back.
kiwi_gg ( ) posted Mon, 26 April 2010 at 12:53 PM
works fine in 6.1
Cheers
GG
WHO said Kiwi's can't Fly ?????
rubidium ( ) posted Tue, 27 April 2010 at 2:58 PM
 Hello
I think that I have read somewhere (perhaps in the DAZ forums?) that Bryce 6.3 had a bug with exporting booleans.
Ramon
TheBryster ( ) posted Wed, 28 April 2010 at 8:08 AM
Forum Moderator
The bug was/is that while you can export a booleaned group when you import it back to Bryce it doesn't behave like a normal 'solid' object.
rj001 ( ) posted Thu, 29 April 2010 at 9:33 AM
i'm away from my Bryce at the moment, but does Collapsing the mesh before exporting help?
Experience is no substitute for blind faith.
http://avalon2000.livejournal.com/ - My Art Blog
