Mon, Nov 11, 12:05 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 11 9:00 am)
Subject: Poser Pro 2010 makes Posette look good!
  • 1
  • 2
SeanMartin ( ) posted Tue, 27 April 2010 at 5:05 PM
And finally...
Bear in mind that a lot of this was done in 2002-2003; at one point, I had over 50 original textures for the little guy that were just experiements never released. I havent even thought about taking the dork into WW and bringing some of Michael's clothing over for him. That could be interesting...
NanetteTredoux ( ) posted Wed, 28 April 2010 at 2:01 AM · edited Wed, 28 April 2010 at 2:06 AM
SeanMartin, Yay for the Dork! That looks great!
Here is Posette rendered in Poser Pro 2010 using DPH's V3 re-map and an African head morph I saved to obj from the P4 Ethnic character set. The texture is Copilote's Lisha, and I used the VSSPr3_NoAO shader. I had to tweak VSS a bit because it was miisinterpreting the ears, thnking they were corneas. Took me a while to figure that out.
DPH, all that layering you do...it gets you the result you want, but I want to render in one pass.
Poser 11 Pro, Windows 10
dphoadley ( ) posted Wed, 28 April 2010 at 2:45 AM
@NanetteTredoux;
That looks fabulous!  If this is the African Head that you were looking for, so much the better!  I render the way I do because it suits me!  Also, when I press VSS into service, I seem to have a singular incompetence in operating it.  Nevermind, I usually have to do a lot of postwork anyway because of pokethrough.  DO keep up your good work!
@SeanMartin;
some of your Dork renders look better than mine!  Good job, and DO keep it up.  The Dork deserves respect!
dph
3dactor ( ) posted Thu, 29 April 2010 at 12:42 AM
dph,
you know what  could provide a nice firelight glow to the room. IDL lighting. Just create a couple props.  red, orange and yellow over in direction of fireplace. turn ambiance up to like say 6  if they are not too far away. you'll have to test it based on your scene. then delete and/or turn off all lights. turn on IDL lighting manual render settings.
 only possible in Poser 8 or Pro 2010 though... It will produce a very nice natural feel to the light.
regards,
jason-
dphoadley ( ) posted Fri, 30 April 2010 at 4:35 AM
@3dactor:
Thank you for the good advice.  In future renders, I'll see what I can do.
Yours truly,
David P. Hoadley
  • 1
  • 2
