Quote - When I export the character as an obj, or 3ds, its very tiny.
This is normal due to Poser's internal scale.
Quote - How do I increase the size (scale) of the model before I export it?
Use the Scale dial (for a figure make sure to use the one on the Body actor).
Your question suggests that you're importing into another program, so unless you're making morphs, you might be better scaling up in the target application.
Yes that will happen depending upon which program you are importing it into. With the new version of Zbrush you don't need to scale anymore, but with almost every other app you'll need to scale up.
If you are using Vue you can scale within that program.
OBJAction scaler s a tool I use all of the time.
Regards
Hi again,
New problem :)
I don't see any option for that one.
I know when I import something, no problem as I can size them up or down.
Thanks
