Quote - > Quote - I have had great success "removing" undeletable parts by selecting the part in the modeling room and setting the size to 0 or 1%. They can be selected by the menu item: select by> shading zone>mane
Thanks much SP. Will give it a try and see what happens.
CHEERS;-)
Shakti
Where do I set the size? Thanks.
You have moved the location of the vertices, not resized them. After selecting the mane, click on the resize tool (far left of screen), then over on the far right, the pallette will read "scale". Change the "global" setting from 100% to 1%.
In the shader room you will have to give those poly'sa shader with 0% for the alpha to make them invisible.
Namaste;-)
Shakti
