Question... does it have to be 0.0? Maybe the program is expecting just a 0.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
0.0 is what i want :-).
In a desperate attempt I am now first writing 1.0 then 0.0 to everything, then afterwards set the values I computed, and in a final step I walk over everything and check if the values are what I think they are... and if they are not => exception
so rather abort than do something wrong.
but still i am not really satisfied.
wish poser was open source :)
I was just thinking that 0.0 might be too precise for whatever program was going to accept them and that it was expecting some non-zero number since you put in the point. Since 0 = 0.0 I'd try just plain 0 at least once to see what happens.
WARK!
The biggest of all mysteries:
SetMorphTargetDelta function in Posers API.
How to call it properly to have a morph target that contains absolutely nothing?
for i in range(len(actor_verts)):
param.SetMorphTargetDelta(i, 0.0, 0.0, 0.0)
This does not work. After it ran, the morph target contains what it was initialized with, e.g. the influence of JCMs.
param.SetMorphTargetDelta(i, 0.000001, 0.0000001, 0.0000001) seems to overwrite the initial values
param.SetMorphTargetDelta(i, 1.0, 1.0, 1.0)
param.SetMorphTargetDelta( )
seems to work
works only for 90% of the vertices
this some looks like either a parameter format error or bad access to memory...
Is there anyone who might know what this function is really doing or how to make it handle 0.0 value properly? I do not know how to debug Posers black heart ;-)
SmithMicro support didnt know either :(
