What system are you running, I've seen this happen in the past and it was due to the graphics driver crashing.
Do you know your video card make and model?
Then of course the standard "are you running all the latest service packs?".
Shawn
McCarthy
www.defyallchallenges.com
Attached Link: http://www.howtogeek.com/howto/windows-vista/easily-disable-vistas-aero-before-running-an-application-such-as-a-video-game/
If you're running VISTA or 7, have you AERO enabled ?If so, try to disable it.
(Or let Poser 8 disable it for as long as it runs)
Fixed some "whiteouts" Poser 8 had when switching rooms.
Thanks, but I tend to think that if it's a "graphics card problem" with a graphics card that works with every other application, then it's actually more like a "Poser problem". I've had Poser since some of the very early versions, and never really use it. I've always had nothing but problems with Poser. Different versions, different machines, but I'm always running up against problems.
I agree that it's a Poser problem... no other application does this. I wait until Poser sorts itself out, which it does most of the time. And then, sometimes it doesn't.
Makes a strong case for ... save - save - frequently save.
Poser 5 use to do this to me many times. Personally, I think it was just the program giving me a hard time. S Also, memory issues. Like stated above Save often
How much memory are you running and are you running other things along with Poser?
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
When maneuvering around the Preview screen (ie, rotating the view), often the screen will flash, go completely white for a second or two, then go back to normal. I've tried changing the OpenGL settings, don't want SreeD (too slow), and now I've run out of tweaks. BTW, the OpenGL display works just fine on all my other 3D applications (Carrara, Lightwave, D|S), so I know it's not a hardware/OpenGL limitation.
Anyone know what's going on? Thanks.
