Sat, Jan 25, 2:11 PM CST
Subject: V4 Texture
MysticDaniel ( ) posted Fri, 07 May 2010 at 2:01 PM · edited Fri, 24 January 2025 at 10:07 PM
 Hi can anyone link me to a really detailed V4 texture with dark thick brows? Detailed brows like real hairs not painted on, with realistic skin. Anywhere on the net would be great!
Thanks
Belladzines ( ) posted Fri, 07 May 2010 at 2:52 PM
Have you looked at the marketplace?
or Daz3d, or even runtimedna?
Outgoing links cannot be posted here in the forum so it might be a good idea to start a search yourself if you havent already done so :)
hborre ( ) posted Fri, 07 May 2010 at 3:15 PM
Online Now!
The only suggestion I can make regarding realistic skin is using Bagginsbill VSSProp.  It contains a skin template which can convert ordinary skin texture into spectacular realistic skin.
Eyebrows can be problem.  Most, if not all, are painted texture maps with displacement masks to give the resemblence of actual hair.  Hair can be grown in Poser's Hair room, however, it will take time to pose and style it the way you would like.
Artemis is pointing you in the right direction, but I think your particular specification might not be met.
Belladzines ( ) posted Fri, 07 May 2010 at 6:44 PM
ok i do need to correct myself, outgoing links can be posted as long as they are relevant to the question being posted....
MysticDaniel ( ) posted Fri, 07 May 2010 at 11:59 PM
 ok thanks guys, i found a dark beauty! Check my gallery soon if you are interested!
