Fri, Nov 22, 11:19 AM CST
Subject: avi on the floor..is this possible?
radstorm ( ) posted Mon, 10 May 2010 at 3:30 PM · edited Fri, 22 November 2024 at 11:13 AM
Greetings all;
I was wondering if it is possible to put animated movies on Poser's floor?
I know it can be done as a background, so just curious :)
Thanks
TrekkieGrrrl ( ) posted Mon, 10 May 2010 at 3:41 PM
 It should be possible, you can assign a movie node to pretty much anything AFAIK,so why not the floor?
Mind you, I haven't actually tried the movie node ever, and I vaguely remember something about setting the frame number ect to make it work :)
Most likely one of the more movie-savvy people will pop in here soon :)
radstorm ( ) posted Mon, 10 May 2010 at 4:01 PM
Thanks for the feedback, trekkie G :)
seachnasaigh ( ) posted Mon, 10 May 2010 at 7:31 PM · edited Mon, 10 May 2010 at 7:38 PM
You can apply the movie to any UV mapped surface.  For a floor, you might plug a simple flashing-color-squares movie into the ambient node to make a disco floor.  Or you could cast "shadows" of blowing autumn leaves.
You don't need to use a frame number node or modify the frame number unless you want to change play speed or shift the start/stop timing.
Plug a wavy movie into the displacement to make an animated water plane, or use it to control the normals and you have swaying windblown grass.
What specifically do you want to do?
Bubbles for the jukebox' neon tubes. ^^
jukebox
Now, a warning:  if you're using Poser Pro or Poser Pro 2010 and rendering in 64bit, you'll likely find the movie node nonfunctional due to lack of corresponding 64bit video codec.  In these cases, I use a matrix instead of the movie node.
LostinSpaceman ( ) posted Mon, 10 May 2010 at 8:14 PM
Quote - You can apply the movie to any UV mapped surface.  For a floor, you might plug a simple flashing-color-squares movie into the ambient node to make a disco floor.  Or you could cast "shadows" of blowing autumn leaves.
jukebox
That 'esplains the other issue I had with PP2010 and rendering a movie!!
radstorm ( ) posted Tue, 11 May 2010 at 3:13 AM
thanks search..well what I was hoping to do is place a flowing river on the ground plane, and have a barge coning down it.
Of course the barge would just be treated as a simple object..but abthow to create the illusions of it actully being on water..
This would be an anination, not a still life
seachnasaigh ( ) posted Tue, 11 May 2010 at 5:09 AM
Attached Link: animated water using an AVI for displacment
If you are going to work on just a ground plane, then you should at least use a displacement map to create stream banks.  It would be better to use a terrain with a stream bed trough formed into the mesh, and a separate water plane, if you can.
Another consideration would be a wake for the barge.  I've done this by using a mesh wake model attached to the boat, and applying the same displacement AVI to the wake which I used on the water, but at different scale.  It certainly isn't perfect, but it's better than no wake.  I often use Jepe's water ripple AVI set.
Here's a streambed terrain and a waterplane with Jepe's AVI using the Cyclorama:
Another animation using AVI water displacement:  (click tiny rectangle)
boat wake and waterplane both displacement mapped with an AVI:
Did this help?  I could also extract the wake mesh from my sailboat, and you can use my streambed terrain if you want it, though right now I'm pretty busy with finishing the TinkerBell's Drive-in Cafe'  model (hence the jukebox. ^^)
You'll need a water AVI.  I just bought a commercial Genetica license, but it's intended for a workstation which I don't even have yet, so it will be quite a while before I can make my own water ripple AVIs.
