Tue, Feb 11, 12:22 AM CST
Subject: Odd Issue
Arah ( ) posted Sun, 09 May 2010 at 1:22 PM · edited Mon, 20 January 2025 at 9:08 PM
i'm having an odd little problem with conforming cloths in poser. i would like to fix it, but i don't know what is even causing the problem. help please?
markschum ( ) posted Sun, 09 May 2010 at 2:01 PM
That looks like the mesh tearing. Check your joint zones.
DarkEdge ( ) posted Sun, 09 May 2010 at 2:01 PM
Looks a little bit like unwelded verts.
ockham ( ) posted Sun, 09 May 2010 at 2:03 PM
This often comes from a missed weld.  Check your CR2 file and be sure
the 'rCollar' is welded to the 'Chest'.
There should be a pair of lines like
        weld rCollar
            chest
and
        weld lCollar
            chest
My python page
My ShareCG freebies
Adom ( ) posted Sun, 09 May 2010 at 2:47 PM
it is most likely what was said above but ...
it happens to me when poser runs to long (has nothing to do with cr2) - probably something gets wrong inside memory and such breaks randomly appear on the figures - restart usually helps.
Arah ( ) posted Sun, 09 May 2010 at 4:57 PM
ok Thank you everyone!
TrekkieGrrrl ( ) posted Sun, 09 May 2010 at 8:12 PM
 Remember that all the collar bits must be a child of the chest bit. You can't have some of them welded to the chest and some to the abdomen for instance. That might be what's wrong here :)
The HIP is the only body part that can have more than one "child" part.
Arah ( ) posted Mon, 10 May 2010 at 1:31 PM
ok Thanks you! will try to Remember!
Arah ( ) posted Mon, 10 May 2010 at 3:52 PM
Re-starting didn't work, and i'm not exactly that learned in poser yet, to understand it all. does anyone have a tutorial that might explain how to fix it? seeing as i'm rather new at all this?
