Thu, Jan 23, 8:41 AM CST
Subject: V4 Front Bodysuit Seam Problem
ghoyle1 ( ) posted Mon, 17 May 2010 at 1:33 AM · edited Thu, 23 January 2025 at 8:30 AM
The front seam on the DAZ V4 bodysuit does not go all the way to the top (as it should if it's to represent a zipper). The one on the M4 bodysuit does, however. Does anybody know ofor can suggest a workaround for this?
Thanks,
Guy
PS Curiously, the seams on the side of a neck do go to the top.
hborre ( ) posted Mon, 17 May 2010 at 9:00 AM
There is a second bodysuit from DAZ which does contain the zipper morph.  IIRC, the product's merchant is billy-t.
chriscox ( ) posted Mon, 17 May 2010 at 12:53 PM
You could try making a morph to "Fix" this with the Morph Brush or a Modeling program or even Magnets.  I personally would do it with a modeiling program (Silo3d) since that is what I'm most familiar with.
Chris Cox
ghoyle1 ( ) posted Mon, 17 May 2010 at 1:14 PM
Yeah, that's an option, but I've never modelled a morph before. I have Cinema 4d, but have mostly used it to make things like spaceships. I think I might try and make a displacement map. (I just don't know what their thinking was with that front seam; as it is, it isn't any good unless you make a transmap for the neck part where the front seam should go.)
Thanks for the advice,
Guy
ghoyle1 ( ) posted Mon, 17 May 2010 at 1:29 PM
Quote - There is a second bodysuit from DAZ which does contain the zipper morph.  IIRC, the product's merchant is billy-t.
Thanks for the advice. Unfortunately, it doesn't seem to be at Daz right now. I found a number of his items, but not much for V4.
Thanks anyway,
Guy
Ghostofmacbeth ( ) posted Mon, 17 May 2010 at 2:10 PM
The easiest fix would be a displacement map applied to match the seam.
ghoyle1 ( ) posted Mon, 17 May 2010 at 2:19 PM
Thanks. I'm experimenting with that now, but I'm lousy at texturing. I'll keep trying, though.
Guy
Mark@poser ( ) posted Mon, 17 May 2010 at 10:33 PM
Quote - > Quote - There is a second bodysuit from DAZ which does contain the zipper morph.  IIRC, the product's merchant is billy-t.
Thanks anyway,
Guy
It's actually here at Renderosity:
http://market.renderosity.com/mod/bcs/index.php?ViewProduct=63352
I believe other vendors make bodysuits with zippers too.
Good luck
ghoyle1 ( ) posted Mon, 17 May 2010 at 11:12 PM
Thanks for locating that. It's a great bodysuit, and I might just get it. What I'm really looking for, though, are similar bodysuits for V4 and M4, so I can make identical uniforms. I really with that the V4 and M4 catsuits were more alike.
Thanks again,
Guy
