Tue, Feb 18, 12:18 AM CST
Forum Moderators: RedPhantom
Subject: M4 Texture
drgnmztr ( ) posted Sat, 22 May 2010 at 5:00 PM · edited Sun, 16 February 2025 at 1:45 PM
Ok, so... Theres not a "general" discussion area for asking questions so I picked this one since I pose my figures in poser.
Question: I am looking for a mat for M4(or even M3) that shows heavy veins coming out of arms/legs/chest etc. Similar to Davids bodybuilder material at Daz. Anyone know of anything?
I am NOT a texture artist. Been there, tried that, failed HORRIBLY..
Thanks guys and gals.
Latexluv ( ) posted Sat, 22 May 2010 at 5:05 PM
I remember something vaguely about vein displacement maps. Hopefully someone will come along who knows more and give you better information than what I remember.
Weapons of choice:
drgnmztr ( ) posted Sat, 22 May 2010 at 5:13 PM
ok.. thanks.. Though I don't know what that means..heh heh..(displacement maps).
hborre ( ) posted Sat, 22 May 2010 at 5:35 PM
Then I would suggest you start learning very quickly.  In many instances, displacement maps will either make or break a render where realistic detail is concerned.  Like perhaps a displacement map veins.  Unfortunately, a veinous displacement map was never created for M3, although I would imagine that David's could be used for M3's mesh.  M4's veinous displacement map was only created for DAZ Studio (pity), however Semidieu @ RuntimeDNA created a python script  which can insert different intensities of displacement.  That script can be found here:
http://www.runtimedna.com/forum/showthread.php?t=40908&highlight=m4+displacement
After you go through that thread, I am going to imagine that you will back with further questions.
And the script does work, I have tried it already.
Diogenes ( ) posted Sat, 22 May 2010 at 6:04 PM
Many of the character sets by Morris have vein displacement maps. I think the "Wood God" by Morris is for M4. Pretty sure it has some displacement maps. Anyway if you look through his character sets I'm sure you'll find what you are looking for.
A HOMELAND FOR POSER FINALLY
drgnmztr ( ) posted Sat, 22 May 2010 at 7:13 PM
thanks everyone.I appreciate it. I probably WILL be back with more ???? I'll check this stuff out. See what I can come up with.
TrekkieGrrrl ( ) posted Sat, 22 May 2010 at 8:03 PM
 I have a free vein map for Mike3. If you've got the Universal Texture Converter from Daz, it's easy to convert to any figure :)
hborre ( ) posted Sat, 22 May 2010 at 11:22 PM
TG, just checked that link and it appears to be broken.
nemesis10 ( ) posted Sun, 23 May 2010 at 3:13 AM
 Try here instead: [www.who3d.com/downloads/M4DisplacementForPoser.zip](http://www.who3d.com/downloads/M4DisplacementForPoser.zip)   Here is an example i just rendered with the Freak 4.
drgnmztr ( ) posted Sun, 23 May 2010 at 1:36 PM
I got the script working fine but my runtime isnt seeing the tifs fromDazs m4displacementmaps..Uhg
Nemesis10,do you need the python script for those?
drgnmztr ( ) posted Sun, 23 May 2010 at 2:12 PM
Well, I loaded basils script and that went fine but the maps won't show up in my runtime. so I DL'd and added the ones Nemesis linked to above. I see the maps and folders in my Poser runtime but when I went to load onto M4, I got this error message:
NULL(or empty)script name passed to PEPythonEngine::DoScript
I'm running PoserPro on a PC with Vista
I went to render anyway and nothing..
anyone have a clue? maybe I need to take out Basils (Semidieus) script?
thanks for any help...
hborre ( ) posted Sun, 23 May 2010 at 2:56 PM
Semidieu's script can only be run from script menu in the taskbar.  You are given the different flavors of displacement.  There are no Library settings generated.  See image above.
hborre ( ) posted Sun, 23 May 2010 at 3:03 PM
Is the script installed in the Poser folder?  And is PoserPro installed within Program Files folder in Vista? (Just a chance of UAC interference if that is the case).
BTW, Both scripts are essentially the same.
drgnmztr ( ) posted Sun, 23 May 2010 at 3:21 PM
Ok,thats different from what I have set up. Everything is in the library folder for Simidieu(except the script). Chris's is set the same way,as per the folder Heirarchy in the zip file.. let me change both.
and yes , poserpro is installed in programs folder in vista.. Nothing has been clear as to where to put the tifs..
hborre ( ) posted Sun, 23 May 2010 at 3:30 PM
Unless there is proper authorization or deactivation of UAC (not highly recommended), Poser installed into Program Files folder under Vista and W7 will experience OS interference and disruption.  The usual recommendation is to install Poser into it's own folder on the core drive.
Perhaps what we are seeing is Windows not allowing the script to run.
drgnmztr ( ) posted Sun, 23 May 2010 at 5:15 PM
hborre
sorry to be a pain..
going along the lines of simidieus script and using the m4displacement maps from daz...
 I have the py file in the scripts library,
poserpro/runtime/python/poserscripts/scriptsmenu
what is the path for the m4displacement maps from daz? I am still not sure where they go since you said there's no library settings....
hborre ( ) posted Sun, 23 May 2010 at 6:59 PM
The exact pathway I have for Semidieu's RDNA d/l is *Poser ProRuntimePythonposerscriptsscriptsMenuCBowmanM4Displacement.
*Load M4, navigate and pull down the Script menu of your menu bar and open as illustrated in the post above.
hborre ( ) posted Sun, 23 May 2010 at 7:03 PM
Once you apply the displacement to M4, you should see the arrangement of nodes above.   Make certain that *use displacement maps* is checked on under render settings before you render your scene.
drgnmztr ( ) posted Sun, 23 May 2010 at 11:17 PM
ok. I'll give that a shot.Thank you.
sorry. Been battling a headache all day and the computer screen hasn't been helping.
hborre ( ) posted Sun, 23 May 2010 at 11:33 PM
Sorry to hear that.  Been there, done that.  Let me know how it turns out.  I double checked my own set up and it works.  I see no reason why your's shouldn't.
TrekkieGrrrl ( ) posted Mon, 24 May 2010 at 7:17 AM
Quote - TG, just checked that link and it appears to be broken.
Argh! Thanks for spotting it! It's fixed now!
guefe ( ) posted Mon, 24 May 2010 at 10:54 AM
Thanks a lot to nemesis for the maps!
drgnmztr ( ) posted Tue, 25 May 2010 at 1:16 AM
Well, I guess I crashed Poser so it wouldnt even open. I copied my runtimes and reinstalled poser and reinstalled my runtimes.
I then placed the py file and the disp maps and ran poser. It worked BUT, high setting really distorted m4, looked like a corpse with muscles. and the fingers got really skinny.Tried it at .50 and worked better but fingers are still skinny and veins don't pop out as much but its better than nothing. Just need to figure out the skinny thing now...
I'll post a pic in my gallery when I get this piece finished.
hborre, I really appreciate all the help.
