Carrara F.A.Q (Last Updated: 2025 Jan 04 8:20 pm)
I assume that converting to a vertex object (not sure how that is done) would freeze the shape. Is the ability to alter the topography the only thing I would lose in doing this? In other words, can I still use terrain shaders on the vertex object and treat it like terrain?
Also, does this response indicate that there is no way to assign shader domains to a terrain?
Thanks.
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device. Beige horizontal case. I don't display my unit.
You can actually adjust the shape further within the vertex modelling room use the standard vertex tools and the displacement tools. Also you can still use the terrain shaders upon the completed model. Sadly you cannot assign shading domains directly to a terrain in its raw state.. it does need to be converted to a vertex object.
To covert the terrain to a vertex object.. select the terrain then go the top menu in the assemble room and select "Edit" then select "Convert to Other Modeller" at the bottom of the drop-down list, from the new window select "Vertex Modeller" and then click "OK". Now click the Vertex room tool (the spanner at the top of the window" and you will find your terrain ready for editing etc.
Hope this helps..
Thanks for the assistance, benney.
Klebnor
Actually, all you need to do is apply the Surface Replicator to the terrain - no need to convert it.
Within the Replicator is a Shading domain function (right side of panel), and just under that is the option to "Use Shader". When "use shader" is activated, the surface replicator automatically creates a new shader specifically for distribution - called the distribution shader oddly enough. With this new distribution shader, you can drag it onto your terrain temporarily and then paint on it, import shader maps etc. After that, you can put the terrain shader back on the object but now you have a new shader for distribution. If you choose not to paint on the distribution shader, you can instead use any of the procedural functions to set a black and white map for distribution, including all of the terrain functions.
Pretty tidy.
Mark
Quote - With this new distribution shader, you can drag it onto your terrain temporarily and then paint on it, import shader maps etc. After that, you can put the terrain shader back on the object but now you have a new shader for distribution.
Mark:
This sounds like exactly what I want. Where (in what room) do I drag the shader onto my terrain temporarily and then paint on it?
Thanks,
Klebnor
Mark:
Cool, thanks. Will give it a try.
Klebnor
Thanks!
I realized greyscale was all it saw, but found that a color is easier to see. I haven't experimented that much yet, but assume that moving up and down the luminance on the color picker will adjust the lightness/darkness.
Klebnor
I want to set up shading domains within a terrain so I can apply surface replicated trees and plants only in specific domains. Can this be done? I see that the surface replicator allows me to restrict the replication to a named domain, but I can't find any way to assign domains to sections of a terrain.
Thanks.
Klebnor von Brunost
