Mon, Jan 27, 5:57 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 5:49 pm)
Subject: Texture Seams in Finished Render
mach ( ) posted Sat, 29 May 2010 at 7:58 AM · edited Thu, 16 January 2025 at 4:30 AM
What firefly render settings should be used in Poser 5 so that the texture seams are not visable in the finished render?
Thanks.
ShaaraMuse3D ( ) posted Sat, 29 May 2010 at 8:02 AM
 Render setting might not necessarily help with that.
When you texture an object, the seams may look fine in the preview because it often has lower texture resolution, and doesn't show bumps, displacement maps and so on..
In my experience, very visible texture seams in render is usually poor texture work rather than a renderer problem.. :) Of course there may be other issues that can cause this too?
Are you using your own textures, or are you using someone else's product?
infinity10 ( ) posted Sat, 29 May 2010 at 8:04 AM
 It it possible to turn off texture filtering in Poser 5 ( I only have Poser 6 +).  That may help get rid of seams in the rendered art.
Eternal Hobbyist
mach ( ) posted Sat, 29 May 2010 at 9:07 AM
Thanks- it was texture filtering that was causing the problem. I' rendering someone else's  product.
The eyelashes look better with texture filtering on- they look too thick and smeared without it.
Thanks again to both you and Grappo2000 (the post above) for your help.
Victoria_Lee ( ) posted Sat, 29 May 2010 at 9:17 AM
You should be able to go into the material room in P5, IIRC, and turn the texture filtering on for just the eyelashes.
Hugz from Phoenix, USA
Victoria
mach ( ) posted Sat, 29 May 2010 at 11:26 AM
What's IIRC?
IsaoShi ( ) posted Sat, 29 May 2010 at 11:28 AM · edited Sat, 29 May 2010 at 11:30 AM
Texture filtering samples image map pixels adjacent to those being rendered. If the texture maps are not adequately overlapped at the seams, some blank pixels can be sampled, and this causes the visible seams.
DAZ Elite skin texture maps are like this. As Grappo2000 said, it's down to poor texture work.
Quote - What's IIRC?
If I Recall Correctly
mach ( ) posted Sat, 29 May 2010 at 12:04 PM
Thanks. I'll try to experiment with that.
