Mon, Feb 10, 10:32 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 10 9:40 am)
Subject: How do I import an object into the library?
Michaelab ( ) posted Mon, 31 May 2010 at 2:07 AM · edited Mon, 10 February 2025 at 10:19 AM
I have downloaded an .obj and .mtl file (a hat) and I want to put it on my character. I'm not sure which folders to put these two files into so that I can access them through the library.
Can somebody help me with this?
Thanks.
Michael
basicwiz ( ) posted Mon, 31 May 2010 at 2:12 AM · edited Mon, 31 May 2010 at 2:13 AM
IT does not matter where you put these files. You just have to know where you put them so you can navigate to them.
Let's say you put on your desktop (just for argument).
  1. Load your character into Poser.
  2. Got to "File," then "Import," then "Waqvefront OBJ"
  3. follow the prompts.
When you get to the screen asking what file to import, navigate to your desktop and click on the obj file.
You should see it automagically appear on your Pose screen. Use the x,y,z trans dials to move it where you want it, and parent it to your character.
You can then save it to your props file for future use.
That's all there is to it!
Michaelab ( ) posted Mon, 31 May 2010 at 2:51 AM
Thanks, basicwiz and I did do that and yes it imported, but I got this large flat plane (as in 2d) that came along with it and was attached to it. I thought if I did it through the library that plane wouldn't be there.
If I do it the way you suggest, how do I get rid of the plane?
RobynsVeil ( ) posted Mon, 31 May 2010 at 6:03 AM
Which programme was this hat created in? That's where you need to separate the meshes (flat plane from the hat).
Metaphor of Chooks
TrekkieGrrrl ( ) posted Mon, 31 May 2010 at 6:59 AM
 You can separate the hat from the plane with Poser's Grouping tool. Select all the parts that belongs to the hat (probably easiest to do with the front camera and wireframe view) Then, with the hat seected (it lights up red), click the Spawn Props button and you'll have a new object in your scene. Delete the one with the plane and save the other one to your props palette/library :)
hborre ( ) posted Mon, 31 May 2010 at 8:15 AM
I agree with TG.  That is, perhaps, the easiest way to isolate the hat and save into the library.
Michaelab ( ) posted Mon, 31 May 2010 at 9:08 AM · edited Mon, 31 May 2010 at 9:09 AM
Thanks TrekkieGrrrl, but nothing happens when I use (click and drag) the grouping tool and then hit the Spawn Props button. It doesn't create a red selection when I drag over the hat and plane. I have Poser 8.
Michaelab ( ) posted Mon, 31 May 2010 at 9:15 AM
I have Poser 8.
