First of all, what is your lighting set up and shadow settings? If the only light is coming head on, then you aren't going to get any shadows down there.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
WARK!
Depending on your scene, you do not need all your lights with shadow on. For example, if you are setting a scene with a daytime sun, 1 infinite with shadows is enough. If there is a fill light available, no shadows is needed. An interior scene with multiple lights may require all the lights to have shadows active. Again, fill lighting would require this.
And don't forget, gang...
Depth mapped shadows are useless.
![file_453769.jpg](https://live.cdn.renderosity.com/forum/threads/2803145/file_453769.jpg)
I have a hat on a character and yes, the hat has shadows turned on, however when I render the image I get a brightness under the brim as attached. Is there a way of getting rid of the brightness under the brim of the hat?
