Fri, Sep 20, 9:36 AM CDT
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 20 6:55 am)
Subject: Under Arm hair nubbies missing from V4 textures! :-)
Eric Walters ( ) posted Wed, 02 June 2010 at 10:54 AM · edited Fri, 20 September 2024 at 9:29 AM
    I don't know why this is bothering me *SLIGHTLY*- but NONE of the textures of any V1 through V4 show that slight shadowing where the shaved under arm hair would be.
 I was marveling at how gorgeous this rendered image is-and it struck me. Funny, eh? :-)
infinity10 ( ) posted Wed, 02 June 2010 at 10:58 AM
.... I believe there are other ways to (permanently) remove underarm hair these days, other than shaving...  Some women achieve a remarkable degree of smoothness.
Eternal Hobbyist
dphoadley ( ) posted Wed, 02 June 2010 at 11:12 AM
And then there are perverts like myself who prefer that our women remain naturally hairy!
dph
NanetteTredoux ( ) posted Wed, 02 June 2010 at 12:55 PM
Yes, I was about to suggest going into the hair room!
Poser 11 Pro, Windows 10
markschum ( ) posted Wed, 02 June 2010 at 1:42 PM
a light touch in photoshop with the spray gun will add stubble. V4 must use Nair and a foundation makeup.  :)
WandW ( ) posted Wed, 02 June 2010 at 2:50 PM
Here's a set of Photoshop brushes that includes a stubble brush-I haven't tried it, myself...
keepwaiting.deviantart.com/art/Skin-Care-v2-Photoshop-Brushes-125078539
bagginsbill ( ) posted Wed, 02 June 2010 at 4:22 PM
I think the hair room way works great. You don't need dynamics because they are so short.
Here are some hair settings.
Shader
Render.
dphoadley ( ) posted Wed, 02 June 2010 at 6:53 PM
And if one wanted to create a 'Bush', what would do for that?
dph
TrekkieGrrrl ( ) posted Wed, 02 June 2010 at 8:10 PM
Quote - And if one wanted to create a 'Bush', what would do for that?
dph
Increase the Hair Length.
bagginsbill ( ) posted Wed, 02 June 2010 at 9:41 PM · edited Wed, 02 June 2010 at 9:41 PM
It wasn't quite as easy as that, TG. I'm not very familiar with the hair room, so I had to do a few hundred experiments to get this.
Also, I get completely different results with shadows on versus off. I'll show the render with shadows on, since I only disable them for quick test renders. Shadowless test renders turned out to be a big waste of time, as enabling shadows changed everything.
Results will vary, also, with the mesh density. I did this with V4. Might need different hair counts with other figures.
First my hair settings.
The shader.
bagginsbill ( ) posted Wed, 02 June 2010 at 9:42 PM
The results.
Note also - rendered in Poser Pro 2010 with render GC enabled. You may find other versions of Poser doing something different, as I know that hair rendering has changed recently.
bagginsbill ( ) posted Wed, 02 June 2010 at 9:45 PM
I know DPH likes'em bushy, so bushy it is.
bagginsbill ( ) posted Wed, 02 June 2010 at 9:59 PM
Note: Apparently the hair length parameter meaning is affected by your choice of Poser Display Unit. I'm in inches, so to use my numbers, use inches.
Eric Walters ( ) posted Wed, 02 June 2010 at 11:38 PM
 HAHA! Thanks everybody!
 BagginsBill- once again you amaze me.
dphoadley ( ) posted Wed, 02 June 2010 at 11:41 PM · edited Wed, 02 June 2010 at 11:48 PM
Quote - I know DPH likes'em bushy, so bushy it is.
Well, it's for my Graphic Novel, and the Posette Swiss Governess needs a Bush for the seduction scene.  The story takes place between the years 1838-1845, and I don't think ladies had as yet gotten into the practice of using their hubbie's - boyfriend's - father's Gillette!
I could, of course, have used the old Bush prop I have, but I was thinking that a Dynamic Hair one might be better.
dph
NanetteTredoux ( ) posted Wed, 02 June 2010 at 11:58 PM · edited Thu, 03 June 2010 at 12:01 AM
David - I would suggest two hair groups for the bush - an inner one with higher hair density, and an outer edge with fewer hairs so it doesn't look too neat for the 19th century. You should do the same for the male, perhaps on the chest too.
infinity10 ( ) posted Thu, 03 June 2010 at 12:58 AM
 Oh wow - we moved from underarm hair to...  heh
Eternal Hobbyist
Xase ( ) posted Thu, 03 June 2010 at 9:09 AM
Quote -  Oh wow - we moved from underarm hair to...  heh
I know!  I was thinking bushy underarms...and then BB gives us the partial monty! :blink:
Although now I have some new ideas to play with.....
primorge ( ) posted Sat, 01 September 2012 at 8:34 PM
Absolutely Awesome... why I love the Rendo Forum!
Blackhearted ( ) posted Sat, 01 September 2012 at 9:22 PM
Quote - And then there are perverts like myself who prefer that our women remain naturally hairy!
dph
its 2012 dude, not 1960.
shudder
primorge ( ) posted Sat, 01 September 2012 at 9:34 PM
Guffaw!
primorge ( ) posted Sat, 01 September 2012 at 9:56 PM
Although this thread is long dead... just an additional suggestion in regard to the pubic sim. You might want to take the underlying body texture into an image editing program (PS, Gimp, Etc.) and subtly darken that skin area where the hair is going to be growing from (Particularly near the center of the growth area, with a fading diamond or cross shape pattern). Perhaps with the Burn tool... It'll make the final result look less sparse.
Dale B ( ) posted Sun, 02 September 2012 at 3:41 PM
I know the current vogue is to remove it all, but as it is nothing but a current fashion trend (probably started to make the bodyart and piercings look neater), the wheel will no doubt spin again. Plus the fact that up until the last century, the only females who could bother with bodyhair removal were the nobles and aristocrats......and the methods used would make the Marquee De Sade tingle in anticipation.
AnAardvark ( ) posted Tue, 04 September 2012 at 12:08 PM
Looks like it would also be good for 5'oclock stubble.
