Wed, Jan 29, 11:31 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 29 10:50 pm)
Subject: WHAT ARE THE ADVANTAGES IN USING POSER PRO 2010 ??
cg3dstudio ( ) posted Wed, 09 June 2010 at 9:12 AM · edited Wed, 29 January 2025 at 11:20 PM
Does anyone have used poser pro 2010 ?
I use poser 8 and Poser pro... Will I have any beneffit in start using Poser Pro 2010 ??
cspear ( ) posted Wed, 09 June 2010 at 10:38 AM
 PLEASE DO NOT SHOUT.
If you want to use Gamma Correction, have a 64-bit OS, would like to render over a network, or use any of the features which are not in Poser 8, PP2010 may be for you.
Compare here.
PoserPro 11 - Units: Metres
Adobe CC 2017
cg3dstudio ( ) posted Wed, 09 June 2010 at 11:15 AM
OK, Can I use my runtime library of poser 8 in Poser Pro 2010  ?
dlfurman ( ) posted Wed, 09 June 2010 at 12:00 PM
Yes. You are able to link to your previous libraries.
ice-boy ( ) posted Wed, 09 June 2010 at 12:43 PM
-fully body morphs
-gamma correction
-hdr rendering
-rendering in passes
seachnasaigh ( ) posted Wed, 09 June 2010 at 9:04 PM
If you have a 64bit computer, Poser Pro 2010 can make use of all of the RAM you've got.  P8 is 32bit only, so while it will run on a 64bit machine, it is still limited to a 32bit memory allocation.
PP2010 has more options for importing/exporting geometries.
RobynsVeil ( ) posted Wed, 09 June 2010 at 9:33 PM
Have a look (search) here on threads dealing with this question: they are legion, and filled with all sorts of valuable decision-enhancing information.
Metaphor of Chooks
KimberlyC ( ) posted Wed, 09 June 2010 at 11:34 PM
Here are a few helpful links:
http://poser.smithmicro.com/comparison.html
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2802257
Also found within the forum:
Poser Pro 2010 advantages:
  • Runs the executable (scene setup, etc) in 64bit, and most important, it renders in 64bit, so you can bring lots of RAM to bear.
  • Extra capabilities in import/export of geometries (Collada, etc.);  important if you model.
  • Render in network, applying all of your computers to a project;  great for rendering animations.
  • Gamma correction rendering
  • Fusion with high-end studios
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
