Thu, Jan 23, 9:23 AM CST
Subject: Poser Pro 2010 crashes
padme ( ) posted Sun, 13 June 2010 at 4:31 AM · edited Sat, 10 August 2024 at 4:31 AM
 When I try to save the scene, Poser give me an error (the same three times...) and the application closed.
Any help?
Dizzi ( ) posted Sun, 13 June 2010 at 4:40 AM
And what's the error message?
padme ( ) posted Sun, 13 June 2010 at 9:43 AM
This one...
magnemoe ( ) posted Sun, 13 June 2010 at 10:05 AM
Do you have enough memory? Had lots of problems with it then I run it on a 32 bit system, two results, crash or it started dropping textures of the figures permanently.
padme ( ) posted Sun, 13 June 2010 at 10:09 AM
Yes, I have 4 Gb. of memory.
Sentinelle ( ) posted Sun, 13 June 2010 at 1:38 PM
What is the operating system in which your Poser Pro 2010 runs?  Windows XP or Vista or Windows 7?  32 bit or 64 bit?
padme ( ) posted Sun, 13 June 2010 at 4:36 PM
 Xp 32 bit
hborre ( ) posted Sun, 13 June 2010 at 6:48 PM
Online Now!
Under General Preferences, do you have Use external binary morph targets checked on?  If you do, try turning it off.
magnemoe ( ) posted Mon, 14 June 2010 at 3:14 AM
I had major problems with poser pro 2010 in 32 bit win xp. Mostly under or after rendering but also during normal use, it ran out of memory and crashed or raised error that it could not find textures, saves after this would lack the affected textures. It has gone away in 64 bit windows 7 even running out of memory does not cause errors, probably because it can use as much swap file it want.
padme ( ) posted Mon, 14 June 2010 at 4:07 PM
 Ok,  unchecking  Use external binary morph targets, solve the problem.
Thanks to all for your help.
