Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 10:01 am)
I had major problems with poser pro 2010 in 32 bit win xp. Mostly under or after rendering but also during normal use, it ran out of memory and crashed or raised error that it could not find textures, saves after this would lack the affected textures. It has gone away in 64 bit windows 7 even running out of memory does not cause errors, probably because it can use as much swap file it want.
When I try to save the scene, Poser give me an error (the same three times...) and the application closed.
Any help?
