Sun, Feb 2, 6:07 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 02 4:55 pm)
Subject: Need help with this Poser directory - where it goes
3DNeo ( ) posted Sun, 13 June 2010 at 11:52 AM · edited Sun, 02 February 2025 at 5:53 PM
I have a few directories in my Runtime>Libraries folder that I don't know where they should go or really what to do with them. The "readme" files did not say anything about them. It appears to be some sort of morphs to aid the user or something like that. However, all of the library poses and character figures load just fine.
As you can tell from the screenshot here, there are several directories like this. I have also posted a screenshot showing what is inside the directory that is highlighted. They are from the vendor "RebelMommy" but I have a few others as you can tell. I thought everything in the "zip" file went to the specific folders and was not sure why the vendors have these EXTRA folders or what they are meant for.
Jeff
Development on: Mac Pro 2008, Duel-Boot OS - Snow Leopard 10.6.6 & Windows 7 Ultimate 64bit, 2 x 2.8 GHz Quad-Core Intel Xeon , 10GB 800 MHz DDR2 RAM, NVIDIA GeForce 8800GT.
3DNeo ( ) posted Sun, 13 June 2010 at 11:53 AM
Here is a screenshot showing what is inside the directory in the first post.
Jeff
Victoria_Lee ( ) posted Sun, 13 June 2010 at 12:02 PM
Jeff, those folders contain the information for custom morphs and they're right where they're supposed to be.  If you move them and then try to use the character, Poser will give you an error and ask you to find the files.
Hugz from Phoenix, USA
Victoria
hborre ( ) posted Sun, 13 June 2010 at 12:31 PM
I concur with Victoria.  They are specialized files and are very necessary for the custom morphs to work correctly.  Resist the temptation to reorganize those.
3DNeo ( ) posted Sun, 13 June 2010 at 1:53 PM
Thanks, I was not sure because I don't know how they are being used. Almost all the time all directories for morphs and character are located INSIDE the "Pose" directory. In fact, those same characters are in my "Pose" directory and work just fine. In other words, the morphs for those characters are all in the Pose directory but the ones from the screenshot are not and are not the same as those in the Pose directory even though it is the same character. That is why I was not sure why those are outside the Pose directory.
Jeff
IsaoShi ( ) posted Sun, 13 June 2010 at 6:41 PM
Sometimes the Pose files contain just a script which calls the morph files contained in the other folder.
There seems to be no convention on where these Vendor/Character specific folders should go, so they end up in various different places. Very untidy, but as noted above if you move them you will break content.
markschum ( ) posted Sun, 13 June 2010 at 8:03 PM
The vendors have decided to make their own morph folder rather than try to put their stuff inside another folder. They are clearly marked but shoyuld be in the readme filelist.
rebelmommy ( ) posted Sun, 13 June 2010 at 10:00 PM
Victoria is correct, the file RMMorphs should stay right where it is inside the Libraries folder.  This folder will conatin additional folders that will be named with any of the characters of mine that you own, and contain that characters custom morphs.
  I realise that many vendors put their morphs or these folders within the Pose folder itself but having a very VERY full pose folder myself  and having to on occassion dig through it to find things every so often I found it beneficial to both myself and many customers to have the main folder that houses all of my characters morphs (RMMorphs) outside the pose folder in the libraries folder, as this folder tends to be less cluttered and easier to manuever through and find things when needed.
If you move this folder none of my characters INJ/REM poses will work.  If you want/or need to move this folder or the folders inside of it you will need to edit each of the INJ/REM poses for each character you have to reflect the new location of the RMMorphs folder.
Hope this helps some :)
Renderosity's "problem Child"
Support Hydrocephalus research.. because a Shunt is NOT a cure!
3DNeo ( ) posted Sun, 13 June 2010 at 10:24 PM
Got it, that makes sense now. I just was not sure what was going on, but now I understand. You are basically using a pointer file in the "Pose" directory to make a call to the folder name in the "Libraries" area. At first I thought these were somehow extra morphs or ones for another purpose, but that clears up my questions.
Thanks for all the replies.
Jeff
