Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 06 11:30 am)
just add a reflection node into the reflection color and an edge blend into the reflection value. set the attenuation to 1.2.
set transperancy to 1 and transperancy edge to 0.
with some car models I find that poly smoothing screws up reflections, to fix it I seperate the windshield with the group editor
TemplarGFX
3D Hobbyist since 1996
I use poser native units
There's also BB's thread on Fresnel effects.
For starters, you could use simple transparency and reflection, like this.
You can give the glass a coloured tint by adjusting the diffuse colour (but keep it dark).
Make sure you turn off Reflection_Lite_Mult and Reflection_Kd_Mult.
I'm using bb's EnvSphere for background & something to reflect.
"If I were a shadow, I know I wouldn't like to be half of
what I should be."
Mr Otsuka, the old black tomcat in Kafka on the Shore (Haruki
Murakami)
Attached Link: http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2803896
The link to BB's Fresnel info can be found in the linked thread shown here.Coppula eam se non posit acceptera jocularum.
If you download BB's 'BazzeMatts#2' from here, the zip file contains a Canopy Glass shader... I use this, or adapted versions of it, with great success. It's not a render hog.
PoserPro 11 - Units: Metres
Adobe CC 2017
Hmm... the windscreen in the first of those last three renders appears to be reflecting the terrain, in spite of the angle. Sounds like weird geometry, perhaps related to polygon smoothing.
I've seen this sort of thing before. I once had a perfectly flat table top (a freebie) producing angled and contorted reflections, even with smoothing turned off for the table. The only way I could fix my render was by laying a square prop immediately above the table surface with the same material.
what I should be."
Murakami)
IsaoShi, Thanks for the reply. I think you're right about the geometry. I like the jeep model and wanted to give it a little more impact when I render. Also to the creator of the Willys MB Jeep, just wanted to let you know I'm in no way criticizing your jeep (I like your work very much) and that the changes made are for my personal use.
