Mon, Nov 25, 1:32 PM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2024 Sep 18 2:50 am)
Subject: Anyone interested in a Hair Pose maker script?
wolfie ( ) posted Mon, 14 June 2010 at 2:16 PM · edited Mon, 16 September 2024 at 4:04 PM
The script I recently wrote for a friend on another board saves fit poses for hair props and figures.  It saves body or root prop trans/scale/rotate and optionally morphs to a pose file.  I made it for her to save her substantial time in making a hair fit pack.
The script can be used on both HR2 and CR2 based hair objects and works and tested in Poser 6 and Poser 7.  It should also function on any prop or figure object and save positional information to a pose file.
Basically, it looks at what you have selected.  It figures out whether its a prop or figure so it can write prop or actor lines to the file.  It then asks you for a filename, whether you want to save morphs, and if you do asks if you want to save only non-zero morphs.  It then grabs all trans/scale/rotate values from the body or selected prop and writes them to the pose file.  If you selected morphs it writes those.  If it was a figure it also asks if you want to save child morphs and if so will iterate through the body parts and write the morphs from them too.  It creates a pose file with thumbnail as though you had used the "Add to Library" function in Poser.
Any interest in me releasing this publicly?
gishzida ( ) posted Mon, 14 June 2010 at 2:51 PM
Sounds way cool to me...
Victoria_Lee ( ) posted Mon, 14 June 2010 at 3:49 PM
Sounds like a great idea!
Hugz from Phoenix, USA
Victoria
OKCRandy ( ) posted Mon, 14 June 2010 at 4:10 PM
Sounds very useful. Great idea, I would be interested. ;)
wolfie ( ) posted Tue, 15 June 2010 at 3:09 PM
Ok, I will package it up and get a readme done for it.  Will let ya know when I post the zip
Victoria_Lee ( ) posted Tue, 15 June 2010 at 3:47 PM
thx
Victoria
