Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
The script I recently wrote for a friend on another board saves fit poses for hair props and figures. It saves body or root prop trans/scale/rotate and optionally morphs to a pose file. I made it for her to save her substantial time in making a hair fit pack.
The script can be used on both HR2 and CR2 based hair objects and works and tested in Poser 6 and Poser 7. It should also function on any prop or figure object and save positional information to a pose file.
Basically, it looks at what you have selected. It figures out whether its a prop or figure so it can write prop or actor lines to the file. It then asks you for a filename, whether you want to save morphs, and if you do asks if you want to save only non-zero morphs. It then grabs all trans/scale/rotate values from the body or selected prop and writes them to the pose file. If you selected morphs it writes those. If it was a figure it also asks if you want to save child morphs and if so will iterate through the body parts and write the morphs from them too. It creates a pose file with thumbnail as though you had used the "Add to Library" function in Poser.
Any interest in me releasing this publicly?
